Friend's Evo, Tcase cracked in half.
Old Aug 12, 2007 | 12:48 PM
Mr. Evo IX's Avatar
Do you think JB Weld would fix this? -Joke. Car was still drivable after this happened, at least for a few blocks to where the flatbed could pick it up. So guys, is this typical carnage? Also, if this is sent to Shep would this be eligible for rebuild rates vs a new Tcase? I've found a few used ones but maybe this car needs a stronger tcase. Specifically what causes the case to break in half like this? (exploding dff? but then why would it drive afterwards?).
Also, owner wondered if he could possibly get warranty replacement? Thoughts? This is a Evo IX MR with 7K miles.
Old Aug 12, 2007 | 01:32 PM
DS-03evo's Avatar
How high was he revving it when the clutch was dropped?
Old Aug 12, 2007 | 01:35 PM
SickSilverNLow's Avatar
that sucks man.....what the hell was he doing when that happened?
Old Aug 12, 2007 | 01:41 PM
boostedwrx's Avatar
Wheel hop?
Old Aug 12, 2007 | 01:55 PM
Mr. Evo IX's Avatar
no hop, 6K, sticky track, Exedy twin, 370whp / 360tq measured with DLL. Wanted to see what the consensus was and if this is common carnage. I thought the IX's had a limited slip in front... seems like it would have held up a little better. I guess everything has it's breaking point. It was a quest for low 12's.
So does anyone know if this qualify's for Shep's rebuild rates? And thanks to everyone who has PM'd transfer case replacements, if he doesnt go with a upgraded case he'll be buying one from a member.
Old Aug 12, 2007 | 02:05 PM
alexsracing's Avatar
he had also run 4 other times that night with wheel hop
Old Aug 12, 2007 | 02:07 PM
red03evo's Avatar
wow, hope everything works out for him
Old Aug 12, 2007 | 02:09 PM
Planet Evo's Avatar
Lucky axle didn't break.
Old Aug 12, 2007 | 02:13 PM
kouzman's Avatar
well something must have gone really wrong! it doesn't make sense to crack open the transfer case like that!
i mean burning the clutch ok... breaking ring-pinion ok... breaking teeth from gears ok... even damaging input shafts ok... but breaking the tc in half, i think its the 2nd or 3rd i have seen all this time that i am involved with the EVO community...
maybe factory defect???
Old Aug 12, 2007 | 02:15 PM
Its gotta be some kind of a factory defect...i seen many evos in 11s and such with nothing like that happening ever to any of them . Good luck.
Old Aug 12, 2007 | 02:21 PM
dan l's Avatar
Yeah thats pretty much a warranty issue.........
/sarcasm
Old Aug 12, 2007 | 02:31 PM
Mr. Evo IX's Avatar
I'm thinking it wont be taken in for warranty repair. Pretty much pointless and a waste of time.
Old Aug 12, 2007 | 02:36 PM
that would have been a lot better than the t-case
Old Aug 12, 2007 | 02:53 PM
VIPGarage's Avatar
holy crap. i've seen a lot of horrible t-cases come through the shop but i have never ever seen something to that extent. I almost want to say well done for really breaking something like no one else has......
hope he can find a good solution to meet his needs.
Old Aug 12, 2007 | 02:59 PM
WickedWhtMR's Avatar
that has to be a manufactures defect... the case itself is defective... the case is not a moving part and if it has never been removed... it cant really be denied as warrenty
