CHeck Engine Light.
Old Sep 10, 2007 | 08:03 PM
FloopyDisk's Avatar
CHeck Engine Light.
I just got done installing Buschur's TBE on Saturday night/Sunday morning.
And tonight my engine light popped on. We had a lot of trouble getting the O2 sensor out of the mid-pipe.
Not sure what it could be, my guess is something to do with the change in air/fuel ratio. It does sound a little whistley, maybe an exhaust leak from an unclamped bolt?
Any thoughts would be great, thanks!
Old Sep 10, 2007 | 08:05 PM
sikrsix's Avatar
You can guess its an exhaust leak or you can get it scanned and find out its probably the P0420 code.
Old Sep 10, 2007 | 08:20 PM
FloopyDisk's Avatar
What's the code mean?
Old Sep 10, 2007 | 08:25 PM
MitsuJDM's Avatar
Catalyst Efficiency Below Threshold
https://www.evolutionm.net/forums/sh...ad.php?t=69304
Old Sep 10, 2007 | 08:28 PM
sikrsix's Avatar
P0420 is Catalytic Efficiency Below threshold Bank 1,it is not that your rear o2 sensor is bad, It means that your TBE w(test pipe or hfc) is not working as well as the stock cat converter and the ecu is telling you this. You need an anit fouler or a rear 02 simulator. Search the forums and you will find all you need. Search for "02 fix", "02 simulator" "P0420" Youll find answers.
Old Sep 10, 2007 | 08:34 PM
MitsuJDM's Avatar
By saying "...not working as well as stock...", you mean it's actually working BETTER as far as performance goes, AKA flowing better?
Old Sep 10, 2007 | 09:14 PM
sikrsix's Avatar
yes.. But the ecu thinks something is wrong.
techghost
Mar 21, 2012 02:55 AM
MrJuls
Jan 14, 2012 10:21 AM
vszutu
Toronto Lancer Club
Feb 3, 2011 02:05 PM
evoevo8
North Texas Evo Club (NTEC)
13
Aug 30, 2009 08:00 PM
U8THIS
Mar 5, 2004 07:42 PM
