Best Full exhaust for the evo
Here's the webpage RnR Racing
Originally posted by timzcat
It just doesn't make sense to vent to atmospere with a MAF because you are blowing off metered air. The only reason for it and the only reason why people do it is the noise it makes.
With any type of cone filter you will hear a recirc valve all day long.
Christ I hear the air going in and coming out!
Obvious recommendation is the Forge valve for price, quality, operation on the Evo. And it is a direct drop in.
I'm going to stick the factory intake box at this point with a Ralliart drop in filter... will upgrading the BOV net me anything...?
Originally posted by Diesel
that's what i've been thinking... so, what is the advantage here to upgrading the stock BOV...?
The stock valve is plastic and does not always seat well and can leak boost because it is not seated. I have seen people say it leaks at idle but that doesn't matter cause it is recircing. The Forge valve is actually open at idle, but again it is recircing so it doesn't matter.
hey spooldswede FYI... The text on the drop down boxes on your site are almost illegible. Oh and you should get the Forge Valve on there under Mitsu engine.
Can't wait to hear from you.
I think I be back in the future for the FMIC too.
I just spent $3000 in flooring so I gotta wait on that.
i'll get on that issue with the site immediately.. that's not good! i see it fine on my computer, but that's not good enough..
i thought the forge valve was up on our site now.. isn't it under evo8 engine? try this link: http://www.renn-art.com/renn-art.com...ne.asp?cat=evo
what kinda mods do you need to do with the VTA BOV...?
any issues arise from switching to a VTA...?
and be aware that this VTA BOV is VERY loud!!! it's like a semi-truck BOV!!!! it freaks people out!.. and i've heard a lot of BOV's!!
it's a personal preference really.. but i do recommend to all serious drivers to go with the recirculating version.. if it's sound you're looking for, then the exact same whoosh sound comes out anyway if you go with a cone filter... or if you do my little air-box mod (i wanted to get a little more airflow) which ends up creating a pretty different but sweet sound... but it's not annoying like some can get in the long run either.. it's just right!
i hope my bov sound comes out in my video..
then u will really understand what i mean.. the best way i can explain it is this (don't laugh) *ptching*
Anyone know the stats on the Forge Evo 8 BOV
Recirculating version. At what vacuum on the nipple does the valve open with 19psi on the other end? I have read on a forum that the stock one opens at 16" of vacuum.
Read my post about 3/4 of the way down the page. I'll answewr any questions you have.
Originally posted by spooldswede
sorry, yeah.. i meant it will hold the boost up a little longer most likely even with the stock boost solenoid.. not the other way around..
it's ok to not do any electronics.. i totally understand. and even in stock shape the evo is a beast!..
the downpipe and O2 housing is ready!!.. it's going into production right now!
i can't wait to get it on my car so i can go down to the track and run some low 12's!!
then i'm going for the bolt-in FMIC (truly bolt-in, using stock piping and no cutting involved.. it literally just pops right in!!) from AMS as well! it gave 20whp for AMS's EVO8!
i'm not sure there will be a titanium version exhaust, but anything is possible!
Originally posted by SmokinJoe
Run the Forge Recr BOV... stock replacement, works great, doesnt f-up the MAF, and gives you about a 3hp gain.
