What Gains for these mods?
Old Sep 11, 2007 | 08:49 PM
Celica2EVO's Avatar
I was wondering what gains I will get from these mods, and what improvements I will see in the HP, TQ, 0-60 and 1/4 mile times?
Mods:
Manual Boost Controller at a constant 19psi
K&N Cold Air Intake
Fidanza Cam Gears
Turbo Manifold
COBB TBE/ NO CAT
Thank You For your help and advice!
Old Sep 11, 2007 | 08:51 PM
tsi2evo's Avatar
you dont need tubular manifold or cam gears!!
Old Sep 11, 2007 | 08:55 PM
tripperfx3's Avatar
+1. Depending on the mani. it might get you 5-10 hp, but its not worth it unless you go to a aftermarket turbo with a stock flange (Evo green for example). Also dont get the K&N. The intake or the drop in. They can cause problems. A better way to go would be an Apex'i cone filter. With the TBE, intake, MBC, and tune i had 272 on a dynodynamics (312 on a Dynojet) with 93. I now make 252 on 91 octane. Every car will be different though.
Old Sep 11, 2007 | 08:56 PM
kikazzdrummer88's Avatar
get an o2 hosuing and a set of hks 272's or gsc S1 and ull be around 330whp and mid-low 12's
Old Sep 11, 2007 | 09:01 PM
EvoVIIIJeremy's Avatar
go to ams or bushurs sites and follow there upgrade path. U need a walbro 255 too. fuel is your friend.
Old Sep 11, 2007 | 09:43 PM
Celica2EVO's Avatar
what would be the best intake? If using the apexi, just the filter, or filter and induction box? Whats wrong with the k&n, and how about the AEM intake?
Old Sep 11, 2007 | 09:44 PM
I am using the k&n cone filter with no problems. It is what ams sold me
Old Sep 11, 2007 | 09:50 PM
Celica2EVO's Avatar
i was just wondering because i was reading where it made 14whp with no tuning, and it also comes with the heat shields? I had a k&n intake on my Celica and my evo came with the drop in K&N and ive had no problems with it! How dess the MAF hook to the K&N or do you only have the cone filter with stock tubing?
Old Sep 11, 2007 | 09:54 PM
APEX1's Avatar
follow my mod path in order and you will be happy.
Old Sep 11, 2007 | 09:56 PM
Celica2EVO's Avatar
sweet! Thanks alot, that really helps!
Old Sep 11, 2007 | 09:57 PM
Boltz.'s Avatar
FCOTM Winner
All you need to know is that you don't want the K&N intake. You can get a vibrant adapter and K&N intake from AMS for like $60. Unless your tuner reccomends the cam gears, don't get them. The turbo manifold is a waste of time.
Best bang for buck mods; Test pipe, cams, open element filter, boost controller, flash.
Old Sep 11, 2007 | 10:35 PM
Celica2EVO's Avatar
thanks, do i need an aftermarket BOV or will the stock one work? If i need a new BOV what is the best one for the price?
Old Sep 12, 2007 | 04:48 AM
jdmevo8313's Avatar
Registered User
stock will work fine for the boost level you looking to stay at.
Old Sep 12, 2007 | 05:00 AM
Sluggo's Avatar
im surprised nobody has commented on this yet, but why are you planning on boosting 19psi (less than stock)?
Old Sep 12, 2007 | 05:10 AM
Celica2EVO's Avatar
Mine peaks at 19 is what the gauge reads, Im pretty sure that the 03 VIIIs were 19 peak and taper back to 16 round redline. I will probly run it at 20 or 21 before a tune and 24 or so after a good tune.
