Invidia o2 Housing and Lower Heatshield
Old Sep 14, 2007 | 11:23 AM
bboy_RES's Avatar
i just installed an Invida o2 housing and since the housing relocates the o2 sensor the lower heatshield doesnt fit on properly. also there are no screw holes in the invidia o2 housing for me to bolt the lower heatshield to. i can only bolt it to the 10.5 hotside. can i leave the lower heatshield off or should i modify it to make it fit? what would be the best way to do this?
Old Sep 14, 2007 | 11:26 AM
jrsimon27's Avatar
is the invidia 02 housing ceramic coated?
i bought the mine from buschur and it was coated for heat issues so the lower heatshield wasnt a concern for me.
good luck
Old Sep 14, 2007 | 11:27 AM
TeKiZeRo's Avatar
You can leave it off. I'm running the Megan o2 and there's no holes to screw the heatshield into that either. I just cut off the bottom half of the heatshield and bolted it onto the manifold. There's a screw hole on the manifold for the lower heat shield. It'll hang on by one bolt but it'll work. Here's a picture:
Old Sep 14, 2007 | 11:29 AM
EvoInvidia's Avatar
You don't need that lower heat shield with that O2.
Old Sep 14, 2007 | 11:52 AM
bboy_RES's Avatar
cool thanks for the quick replies!
Dvolution
Jun 1, 2014 02:08 PM
SpeedCircuit
EvoX 'For Sale' External Engine / Power
May 20, 2014 08:06 AM
joshd
Mar 21, 2006 11:55 AM
RS2
May 29, 2005 02:50 AM
memo3
36
Dec 17, 2003 01:44 AM
