2200cc injectors
2200cc injectors
http://www.magnusmotorsports.com/oth...ucts/index.htm
Does any one know if these will work with e85/e98? If they can it would be a great option for people maxing out there 1600's.
Yes, they are good with e85 or e98. Methanol is an alcohol base fuel. If they withstand methanol, they will hold up to ethanol. You would need quite a big set up to require these, and I would suggest if you do need that amount of fuel to consider 8 1000cc injectors. or 8 1200cc injectors. Injectors that are too large are very hard to control at low duty cycles, under low load conditions, and may make the car sluggish. Good luck.
