EVO 8 and EVO 9 gearing....
Old Sep 22, 2007 | 06:03 PM
Corey's Avatar
Don't tell me to search cause I did and all I got was a blank white screen.
I wasn't aware of the gearing change until I seen someone mention it on here. Whats the difference between the two if you guys don't mind answering? After running my car around lastnight, it seems that 5th gear is shorter and it seems to go to only 110mph.
Can someone tell me what the 8's and 9'd do in 4th gear and why the gear change in the 9's?
Thanks.
Old Sep 22, 2007 | 06:55 PM
kaonashi's Avatar
search :P cause ive found this answer myself.
5th is only different gear
Old Sep 22, 2007 | 07:02 PM
kreionic's Avatar
Ohh btw its only the 1st and 2nd gears that are different. Evo9 has shorter gears in those 2
and 4th not sure about 3rd but it would make sense. 5th is the better gear in the 9 than the 8
Old Sep 22, 2007 | 07:05 PM
kaonashi's Avatar
huh, i though it was only the first 2 ;/
One sec ill post gear ratios
Old Sep 22, 2007 | 07:09 PM
kaonashi's Avatar
Evo 8 5spd:
1............... 2.785
2............... 1.950
3............... 1.444
4............... 1.096
5............... 0.825
Final gear 4.529
Evo 9 5spd:
5............... 0.761
Final gear 4.529
Well there ya go
Old Sep 22, 2007 | 07:11 PM
kaonashi's Avatar
So 5th gear is only difference in the 2 This is for 5 spd only. and these are mitsubishi Specs
Old Sep 22, 2007 | 07:20 PM
Evoryder's Avatar
evo9 4th gear is shorter...few guys upgrade their Trannies and replace with the 8 4th gear...
OP: you obviously didn't search in english.
https://www.evolutionm.net/forums/sh...orter+4th+gear
Old Sep 22, 2007 | 07:54 PM
Kc2Buk's Avatar
I found this post some time ago...
https://www.evolutionm.net/forums/sh...opinions+Speed
Originally Posted by 05-EVO-GSR
What are your thoughts/opinions of the new 5 Speed. I was comparing the ratios and I wanted to know how this affects the driving.
03-05 EVO 5 Speed Ratios
1st : 2.928
2nd: 1.950
3rd : 1.407
4th : 1.031
5th : 0.720
Final : 4.529
06 EVO 5 Speed Ratios
1st : 2.785 (higher)
2nd: 1.950 (same)
3rd : 1.444 (lower)
4th : 1.096 (lower)
5th : 0.761 (lower)
Final : 4.529 (same)
Does it buzz more RPM's at cruise on the highway?
Is the acceration in 1st gear worse?
Do you feel any benefit with the lower ratios in 3-5?
TIA!
Old Sep 22, 2007 | 07:55 PM
mhgsx's Avatar
Evo 8 5spd:
Final gear 4.529
Evo 9 5spd:
Final gear 4.529
Well there ya go
Sorry, but NO WAY this is correct. I've owned both. 3rd, 4th, and 5th are shorter in the E9.
Old Sep 22, 2007 | 08:11 PM
kouzman's Avatar
i concur!!!
The ratios you posted are off...
The IX has longer 1st gear and all others shorter...
Old Sep 22, 2007 | 08:24 PM
StreetThisEvo's Avatar
I recently had my Evo 9 - 5spd tranny built by Daniel at Buschur Racing. I had him install the Evo 8 fourth gear to help with my trap speeds.
Evo 9 - 4th gear 118mph @ 8000 rpm (Before tranny rebuild - Stock OEM tranny)
Evo 8 - 4th gear 128 mph @ 8000 rpm (After rebuild)
Old Sep 22, 2007 | 08:31 PM
kaonashi's Avatar
This came from a mitsubishi dealership site sorry thats what mitsu says.
Old Sep 22, 2007 | 08:37 PM
ethompson's Avatar
Corey, hey man just saying hi I saw the thread and sure enough it was you. Let me know when you wanna go out and I ll be there
Old Sep 22, 2007 | 09:18 PM
Corey's Avatar
Your search obviously didn't get you the right answer cause just by driving my car I had a really good idea that 4th was shorter than my 8's. Also seeing people swapping out the 9's 4th gear out for a 8's gave me a idea as well.
1st, 2nd, and 3rd all feel the same to me, but lastnight doing some spirited driving, I noticed I shifted out of 4th really soon. Anyone know the reason for the gear change?
Old Sep 22, 2007 | 09:22 PM
Corey's Avatar
Sup man? Nice meeting you lastnight. We'll have to get together sometime with some other local EVO owners. Car looked nice lastnight. I love that color.
