engine swaps
Old Apr 1, 2002 | 09:44 AM
trickedclips's Avatar
Question engine swaps
hey i have a 99 eclipse gs and i want to swap a japanese 4g63 from a galant or a lancer. is this possible and has it been done before? what about swapping a 2g 4g63 turbo from a gst in america?
thanks
Old Apr 2, 2002 | 12:27 AM
Lan Evo's Avatar
Is your GS equipped with a 2.0 4A20 engine or a 2.4 4G64 engine. The first one is built by Chrysler, and should be located on the passenger side of the engine bay. The 4G64 is a Mitsubishi motor, and should be located at the driver side.
If you have the 4A20 engine, the easiest way to get more power is to get a Hahn racing turbocharger kit.
http://www.hrchahnracecraft.com/hahn/index.htm
If you have the 4G64 engine, you should be able to fit the 2.0 4G63 turbo engine from 90-92 Galant VR-4 or EVO I-III engine and bolt it to the GS-T tranny.
However, either case, it would be much more cost efficient to get the GS-T or GSX than turbocharging/swapping....in my opinion. Just use the $ you save for the swap and sell your current car, you should be able to get a decent turbo DSM....
Old Apr 2, 2002 | 06:58 AM
engine swaps
thanks man. im still gonna try to get that evo engine though because ive put way too much money into the appearance. wide body, custom interior custom M3 astoril blue paint roof scoop and supra taillights... if anyone else knows if it is possible to swap out a 420A for a 4g63t then let me know. thank anyways lan evo for helpin me out
Old Apr 2, 2002 | 08:55 PM
okitenik's Avatar
Dude just get yourself an EVO! You'll save yourself lots of trouble....
Old Apr 2, 2002 | 10:06 PM
Lan Evo's Avatar
Re: engine swaps
Although the location and the dimension of the 420A is similar to the Mirage and EVO engines, however, the 420A engine mounts will not work with the Mitsu engines. You will have to re-weld the mounts just to fit the 4G63 into the engine bay.
IMO, getting that Hahn turbo kit would seems more feaseable.
Good Luck
customtoyz
Jul 22, 2017 08:33 AM
bnr34rb26dett
Oct 31, 2015 09:45 PM
soulesswarrior
23
Oct 16, 2008 04:12 PM
noriceoz
Lancer Engine Tech
16
Nov 24, 2004 07:19 AM
lanceroz84
Feb 13, 2002 12:18 PM
