Turbo timer HKS type 1???
Old Jul 9, 2003 | 09:39 PM
2Evo4U's Avatar
Ok...I installed the hks turbo timer and everything is working properly except for the main function..THE IDLE TIME FOR THE CAR TO SHUT DOWN....I pull the hand brakes up and turn the ignition off. But the Turbo Timer just shuts down with the car...I thought its suppose to count down and shut down according to the setting (30 secs). But when i turn the ignition just 1 click back with the keys still ATTACH to the ignition its counts down and shuts the car off. I want to just turn the ignition off with the keys out of the ignition and walk away while the car idles to a shut down. How do i do that??????
Plz help Im confuse...i hope thats now how turbo timer's work.
Old Jul 9, 2003 | 09:40 PM
nastea's Avatar
hrmm you might not have the e-brake sensor tapped right
Old Jul 9, 2003 | 09:47 PM
SilverEvo8owner's Avatar
no
try checking all the attachments
Old Jul 9, 2003 | 09:49 PM
do you use a harness?
Old Jul 9, 2003 | 09:54 PM
nastea's Avatar
excuse me, i'm ****ing all wrong
Old Jul 9, 2003 | 09:55 PM
huh?
Old Jul 9, 2003 | 09:59 PM
if you used a harness i dont know what is wrong
but if you didnt
it could be that your power source is connected to an accessory
so when you turn the key to the off position you cut the power
Old Jul 9, 2003 | 10:13 PM
PM me if you have any other quesitons about it
tell me if you get it fixed too
Old Jul 9, 2003 | 10:57 PM
2Evo4U's Avatar
Does it matter where i ground the wire too??
E-brake is tapped right... becuz i push the e-brake down and
the car shut's off right away.
And where is the power source located at?? what wire is it?
Yes i have a harness and it fits pretty good.
Old Jul 9, 2003 | 10:59 PM
Chris in HB's Avatar
Make sure you have the parking brake set before you turn it off. That might be the problem.
Old Jul 9, 2003 | 11:01 PM
2Evo4U's Avatar
parking brake?? not the e-brake??
Old Jul 9, 2003 | 11:03 PM
Same thing - technically it's a parking brake... That has to be up before you turn the car off or else the sensor will reset when you pull it up and turn the turbo timer (and the motor) off.
Old Jul 10, 2003 | 12:30 AM
2Evo4U's Avatar
yea i did that already and same thing happens. Parking brake was up....i turn the key to the point where i can take the key out and poofff the cars turns off....this sux....
i already tried to turn the key back 1 click with the parking up.....and while the timer was counting down...i pulled the handbrake down and poof the car shut down...so that should show me that the e-brake is correctly wired up....
i need more suggestions
Old Jul 10, 2003 | 04:14 AM
EvoJimbo's Avatar
Also you will want to check your count down settings. If you are in the automode, and the counter is at 0, the car will just shut off. Automode calculates the estimated idle time needed. If you run the car hard, the auto mode will show a value. If you run under boost, the timer will be at 0. Choose either manual mode, mode 1 or 2. I believe mode 1 is 1 min and mode 2 is 3 mins.
Old Jul 10, 2003 | 04:21 PM
Coolguy949's Avatar
What harness are you using? it should be the HKS MT-6 or the Greddy one. They both work with the Type 1/0 and the evo. If you are 100% sure you have everything wired right, you need to call the place you bought it from to get a replacement.
Post the colors of the wires you tapped for us. I've installed several TTs already so I can tell you what you need to do. There's also a tutorial by one of my customers .
Rob
740 Turbo Brick
May 7, 2014 05:37 PM
gudmundur
11
Jul 19, 2008 01:21 PM
vr4_211
Dec 4, 2005 09:22 PM
o00o
18
Feb 5, 2004 10:32 AM
Thoe99
Jun 30, 2003 09:44 AM
