5th gear grinding????
Old Oct 14, 2007 | 09:11 AM
Chompx88's Avatar
well whenever i shift at higher rpms into 5th it makes a quick grind sound. but it doesnt seem to do it at lower rpms. whats wrong and what can i do to fix it. thanks.
Old Oct 14, 2007 | 09:15 AM
quick silver 8's Avatar
syncros, i have the same problem
Old Oct 14, 2007 | 10:31 AM
Luis@TTP's Avatar
don't shift fast into 5th ever
Old Oct 14, 2007 | 10:38 AM
groove304's Avatar
my fifth did the same thing. Mitsu had to replace the synchro and fifth.
Old Oct 14, 2007 | 10:43 AM
bevolucion's Avatar
FUNNY my evo does the same thing, how many miles in your evo?
Old Oct 14, 2007 | 10:44 AM
bevolucion's Avatar
take it easy with the shifting
Old Oct 14, 2007 | 11:27 AM
lancersibling's Avatar
enjoy! I had the same issue early this spring. Thats how I was able to convince the wife to let me send my x-mission, and since it was out send the transfer too, to Shep for rebuild. Also did my clutch at that time.
Old Oct 14, 2007 | 11:30 AM
evobeatsti's Avatar
mine does it also, but my car is modded, do you think mitsu would honor that?
Old Oct 14, 2007 | 11:33 AM
Evo2wIsh4's Avatar
I have the same problem but I dont want to take it to the dealer because i dont know what they are going to say.
Old Oct 14, 2007 | 11:35 AM
^^^ not likely. I wasn't gonna get that lucky so I went with Shep. You have many parts installed but it doesn't hurt to ask. The deakership told me they would have to drop and disassemble the tranny before they could decide warranty or not. Sounded like BS to me but whatever. Hopefully your dealership will handle it better.
Old Oct 14, 2007 | 11:50 AM
Evoryder's Avatar
My 5th doesn't grind...it's just notchy. My 5th gear changes are very deliberate...don't want to make the mistake most do and shift from 4th back to 3rd ....
Old Oct 14, 2007 | 08:01 PM
Chompx88's Avatar
i got 53000 on my evo. and how much are synchros and it hard to do by myself?
Old Oct 14, 2007 | 08:48 PM
duracell55's Avatar
bushwaker or shep rebuilt parts are expensive and labor is intensive and of course you have to know what your doing. Your choice if you try let us know this is the second thread on this issue at the forum right now which means we are not alone (unfortunately)
Old Oct 15, 2007 | 01:58 AM
nightferret's Avatar
my 5th grinds as well. it really bugs me i cant rev out my 4th without grinding into my 5th.
has anyone ever done there own syncros on there 5 speed?
Old Oct 15, 2007 | 02:06 AM
chrsevx's Avatar
Same fifth gear grind since the beginning then they service center said they would have to disassemble the tranny put in a stock clutch because the one in the tranny was slipping charge me for the stock clutch and labor then see if my 5th gear synchro would still be grinding they were acting like it was because of the clutch like alot of evos dont have that problem. Why would I want another stock clutch when I could get a better one for less I was tight when they said they would have to put a stock clutch in. I said forget it and left the tranny how it was.
