FP Green and Me....the 1,000,001 thread...
Old Oct 26, 2007 | 07:26 PM
Lancerguy'03's Avatar
in Iraq and having this work done to my car pretty much as we speak. to keep me and my mind entertained what are some resonable numbers i should expect with this set up?? i read a lot of threads but deciphering mods to race gas to meth to 93oct is getting crazy. if you have a green and similar set up show some graphs.
04 Evo 8 RS:
FP Green Turbo (ported/coated) @ 30-31psi
HKS 272s
ACT Clutch/Prolite flywheel
AMS LICP
HKS Intake
Ported and coated Manifold/02 housing
Shepp (stage 1) T-case rebuild
Greddy EBC
HFS-5 Aquamist (meth injection @ 100% meth)
short shifter/steel clutch line/bushing/motor mount etc.
3in XS Power TBE (cat delete/no resonator)
help me help you.
Old Oct 26, 2007 | 07:31 PM
SuPeRNeT's Avatar
Here's mine at 26 psi on 105 oct.. Same car ('04 RS FTW Rareist evo out there) and similar mods..
Old Oct 26, 2007 | 07:35 PM
SuPeRNeT's Avatar
Dont mind the spool, high altitude.. Yours will look alot better!!
Old Oct 26, 2007 | 07:36 PM
ok, cool thnx, so with the logic that 1 psi adds appx 10-12 whp.....if u were to run 31psi, you would be arond the 400whp mark.
alt is around 700feet...
Old Oct 26, 2007 | 07:42 PM
scottatyamaha's Avatar
^Those numbers were on a DynoDynamics Dyno, on a DynoJet he would of put down around 415-420
Old Oct 26, 2007 | 07:43 PM
SuPeRNeT's Avatar
Sure mabey more.. Altitude and more boost I would say so.. What dyno are you going to strap it too?
Old Oct 26, 2007 | 07:54 PM
EVOclub4's Avatar
hope that kinda helps some i have more mods now so i have no idea what i may be putting down...as far as i know, i need a new tune with the new mods ....using stock ECU
mine is an '05 btw
i duno if im going to actuly dyno it, but i will have the Evodata log dyno. im just looking for numbers to expect, so everytime i got out in a hummv i can imagine ____whp ____wtq.
Old Oct 26, 2007 | 11:43 PM
RazorLab's Avatar
It will not hold 31psi at peak horsepower.
Old Oct 26, 2007 | 11:48 PM
recompile's Avatar
Do you know how much it will hold?
I'd like to be able to run a flat 25psi boot line from 3750 to 7000
Old Oct 27, 2007 | 12:16 AM
RazorLab's Avatar
You can get close to that with a good Actuator, boost control and good flow.
I've personally seen/tuned a FPgreen hold 25psi at 7300 in 3rd. 25.5psi in 4th. With FP actuator and GM boost solenoid.
The Forge actuator should hold more. I have one on my desk I will be testing soon.
Old Oct 27, 2007 | 09:07 AM
bump for more! im getting excited and cant wait till im home....
Old Oct 27, 2007 | 10:04 AM
electricevo's Avatar
Here is mine...
Mods in sig. 93 octane 23psi. Youll love the setup
