Stock O2 sensor replacement alternatives?
Old Nov 27, 2007 | 07:57 AM
Ludikraut's Avatar
Does anyone know if I can source the stock narrowband O2 sensor from someone other than Mitsubishi? IIRC the Mitsu sensor is somewhat overpriced...
l8r)
Old Nov 27, 2007 | 08:29 AM
Jeff_Jeske's Avatar
I run leaded race gas 24/7 and wanted a spare O2 "just in case". I made a post in the wanted forum and got a like new used O2 from a fellow EVO owner.
I paid $75 shipped. I recommend doing the same.
Old Nov 27, 2007 | 08:37 AM
dubbleugly01's Avatar
you can pick up a generic bosch 02 sensor from any local auto parts store. The only difference is the plug won't match, but that's an easy fix. I forget what I paid for mine, it was cheap though and works perfectly.
Old Nov 27, 2007 | 09:32 AM
Ludikraut's Avatar
Will any Bosch work, or is there a specific part number that I need? I'd rather not go the route of a used one ... I just don't trust used O2 sensors.
l8r)
Old Nov 27, 2007 | 09:39 AM
topnitroracer's Avatar
If you are looking for great plug n' play o2 sensors you can get them at http://oxygengeek.com/. The SNG sensors they sell are great and you cant beat the price with the connector! There is no reason to pay $230+ for a Mitsubishi labeled Denso o2 sensor.
The Front o2 sensor (SN4-126) is $48.67
http://oxygengeek.com/item.wws?sku=S...tid=oxygengeek
The Rear o2 sensor (SN4-60) is $63.94
These guys were great and I got a replacement 2 days after I ordered.
Old Nov 27, 2007 | 09:43 AM
ottomatic's Avatar
Try this: http://www.autopartswarehouse.com/sh...hi/lancer.html
Old Nov 27, 2007 | 09:49 AM
l8r)
I still have the box mine came in at the house if you don't mind waiting till this evening for the part number.
Old Nov 27, 2007 | 10:45 AM
Lowell787's Avatar
I've got a stock one I pulled off my car at 22K. I thought it was a bad O2 sensor, but it was a dirty MAF probe. You want it? Name your shipped price and PM me.
Old Nov 27, 2007 | 11:45 AM
MDUBS's Avatar
Your o2 Sensor
I need an o2 sensor. Is the one you have for the front or the rear?
Old Nov 27, 2007 | 12:37 PM
CrackerJackToy's Avatar
If you run race gas, just unplug your rear o2 sensor & dont worry about it getting fouled out
Old Nov 27, 2007 | 12:39 PM
sabastian458's Avatar
The only difference between the sensor is the length of wiring and the type of connector. I would pick up any generic sensor, and splice your factory connector onto the replacement sensor
Old Nov 27, 2007 | 03:50 PM
here's a link to the exact bosch unit i've been using for over a year. I have a wideband also, and I idle and cruise at 14.7:1, so I know it's working.
$35 and change.... you can't beat it. 4 wires to hook up, and there are instructions on which colors tie into which wires on the factory harness.
http://oxygengeek.com/item.wws?mfr=Bosch&sku=SN4-105
It's Bosch part number 15730.
Old Nov 27, 2007 | 04:00 PM
hk2ronin's Avatar
www.oxygensensors.com
Old Nov 27, 2007 | 07:48 PM
Ludikraut's Avatar
thanks guys.
CrackerJackToy, I'm looking to replace the front O2 sensor, not the rear O2 sensor. Can't just unplug the front one, unfortunately.
l8r)
Old Nov 27, 2007 | 07:53 PM
04AWDTURBOEVO's Avatar
Great Source, great Customer Service, Great Prices : http://www.automedicsupply.com/index...440&height=900
I allways do business with them, .
