Exhaust Manifold install sequence (tightening nuts)
Old Nov 27, 2007 | 08:26 AM
Profoxcg's Avatar
is there any especial squence to to tighten the nuts to the block and turbo housing? similar to when you tighten the wheels of a car?
if so where can I find this information? thanks
Old Nov 27, 2007 | 08:39 AM
dubbleugly01's Avatar
if you mean tighten the exhaust manifold to the head, start from the inside and work your way out. Not sure on the turbo housing.
Old Nov 27, 2007 | 09:11 AM
stryfetew's Avatar
According to FSM you start 2 out side and work your way in. There was a post around here about it.
Old Nov 27, 2007 | 09:52 AM
you want to start from the center. If there is any deformity in the flange, you can work the deformity out towards the edges as you lock down the center of the manifold first, and move outward. If you lock the ends down first, there is nowhere for the deformity to go.
Old Nov 27, 2007 | 10:01 AM
sabastian458's Avatar
centre out.
Old Nov 27, 2007 | 10:35 AM
Profoxcg's Avatar
very insightful thank you !
Old Nov 27, 2007 | 11:22 AM
James@DSR's Avatar
You want to start from the center out like everyone else said. It is also a lesser chance of leaking through the gasket when you're finsihed.
James
Old Nov 27, 2007 | 01:37 PM
C6C6CH3vo's Avatar
Whatever pattern you choose (FSM or whatever), good thing to progressively torque them several times until you reach target value. But good luck getting an accurate value on two of the bottom ones.
Old Nov 28, 2007 | 07:57 AM
stryfetew's Avatar
That is true.
Old Nov 28, 2007 | 10:43 AM
dancarroll0283's Avatar
Start form the center, and work your way out in a criss cross pattern... I've always done this wat\y, and never had leaking
Old Nov 28, 2007 | 12:28 PM
SLVROZ_03's Avatar
Basically like you would on the head studs...inside out & if you feel like it, torque step it.
metalsaber
12
May 29, 2012 09:55 AM
kuvesh
Nov 3, 2010 09:42 AM
Lil red '03
Oct 29, 2005 03:32 PM
Monkey
Sep 13, 2005 08:41 PM
2002OZ
Lancer Troubleshooting
13
Oct 17, 2003 06:22 PM
