dipstick coming out
Old Dec 7, 2007 | 06:39 PM
lockadam2112's Avatar
dipstick coming out
my dipstick keeps on coming out not all the way out though but it comes out a little bit so maybe the pressure wants to come out of the dipstick
does anyone have this going on.
Old Dec 7, 2007 | 06:43 PM
evo8426's Avatar
several people have had this problem and you wouldve seen if you wouldve searched. but ill go ahead and give you a link to solve the problem.
https://secure.buschurracing.com/cat...43e8ecdbbddeb9
Old Dec 7, 2007 | 06:44 PM
geardog75's Avatar
happens all the time most people either zip tie it in place or use a heavy duty spring to hold it in place. i believe buschur sells them on their website, nothing to worry about
Old Dec 7, 2007 | 06:46 PM
Silver06evo9mr's Avatar
if you run alot of boost this will happen
Old Dec 7, 2007 | 06:52 PM
TSiAWD666's Avatar
A cheap way to hold it is is to put a small hose clamp around the dip stick tube near the end, and then use a zip tie that is just tight enough looped through the dip stick handle and around the screw area of the hose clamp. Re-usable since you can slide the zip tie on and off.
Old Dec 7, 2007 | 06:54 PM
kreionic's Avatar
CBRD sells an o ring for the dip stick to help in this situation aswell
Old Dec 7, 2007 | 08:04 PM
thanks eveyone!!!
Old Dec 7, 2007 | 08:19 PM
rcheung's Avatar
I have actually used both. I had the spring by buschur and am currently using the O rings by CBRD. Even though I never had the dipstick pop out even after many autocrosses I figured I would do it just to be safe. The buschur spring is a very stiff brake spring and I sometimes need pliers to put back on the dipstick bracket. When I would take it off it would sometimes get away from me and fall down under the dipstick bracket. This was a problem because I check my oil every week and the process was a bit annoying. Also If I wasn't careful I would get my sleeve dirty retrieving the spring from the bottom of the dipstick. If I had only kept it on when I was racing and not all the time it would probably be fine.
As far as the replacement O rings are concerned, they work much better for me. I dont have to worry about dealing with a spring each time I check my oil and you can see how well the O rings hold the dipstick in there because it takes considerably more force to pull out the dipstick than with the stock O rings.
Old Dec 7, 2007 | 09:27 PM
BURNALL_4's Avatar
I've got one!...its a cheap and easy fix .
Old Dec 8, 2007 | 08:22 AM
CBRD's Avatar
our little orings work well, and are cheap...
cb
Old Dec 8, 2007 | 01:22 PM
Kracka's Avatar
Check out Krank Vents, they create a crankcase vacuum and keep the dipstick sucked in.
Old Dec 8, 2007 | 01:31 PM
antonio010's Avatar
You can also buy your own o rings at any parts store.
Old Dec 8, 2007 | 02:02 PM
lurkerpika's Avatar
i want the over priced ones though....... they add an extra hp?
Old Dec 8, 2007 | 02:17 PM
Gusl's Avatar
simple fix. Discount auto parts sell 2 springs in a pack for $1 & change. Both ends are straight so you just need to cut to length and bend the ends. Simple as that.
Old Dec 8, 2007 | 02:23 PM
CBRD's Avatar
we sell them for 2.50 shipped, viton rings... same id as stock, slightly larger od, impervious to oils etc....
cb
