Tranny / clutch problem ?
Hey whats up guys, so I recently came upon a problem in my car. First of all the car is an EVO IX SE with basically a Precision SC61 turbo and the required supporting mods along with it (Stock ECU). Clutch is an ACT Extreme Heavy Duty. So driving my car over the weekend, I started noticing that the car kinda struggled going into 4th gear. After driving for awhile, I noticed it wouldn't go into 4th gear at all, so I just took the car home and let it sit. I tried driving it the next day and the car went into all gears fine, with a little bit of struggle going into 4th, but it was indeed grabbing. Now today I drove to TTech for a visit and noticed right off the freeway 3rd and 4th gear wouldn't go in at all. The shifter would go into the gear, but it wasn't grabbing, which led me to believe it was a clutch problem. After playing with the stick with the car off, I tried to drive it again and this time 4th wasn't grabbing. Initially I thought it was a tranny problem, but was bamboozled when 3rd started not to grab instead of 4th. Any input, thoughts, or ideas ?
adjust your clutch pedal,,,, ACT clutches have a history of being harsh on our trannies,,,,, your syncros Shepperd tranny will re-build for 900 cant beat the price for all the work he does, once you get the tranny back from him it will be something you can beat on and beat on there are cars running that tranny with over 1000 WHP, car like AMS drag car and time attack,, Buschur, Al Dynoflash,, procco evo and tons more
pretty much i only got like 16k on the car right now, 3rd pops in but its not doing anything, just revs up and 4th works when it wants too. it did grind on 4th when i downshift but then it just started to get bad.
you're saying when you get in gear the car is not grabbing? like the clutch is slipping?
I know with ACT's you have to adjust the clutch pedal. I would also bleed the clutch system.
Please explain yourself properly.
