engine stalling when shifting to neutral problem need help
Old Dec 17, 2007 | 09:39 AM
jenx1976's Avatar
Unhappy engine stalling when shifting to neutral problem need help
car starts and idles ok but has a clicking sound from th engine., drives ok but then whenever i shift to neutral on stop signs, the idle drops and the car stalls., but if i give it gas, the idle goes back up....anybody had this problem before??? PLEASE HELP!!!!!
MODS:
cams+ gears,TBE, intake,IC+pipes,Fpump,MBC
05 VIII with 23000miles
Old Dec 17, 2007 | 11:18 AM
MRfabolous's Avatar
do you have a BOV if so what type that could be causing the stalling
Old Dec 17, 2007 | 11:19 AM
incandescent's Avatar
vacuum leak
Old Dec 17, 2007 | 11:27 AM
JordanS4's Avatar
tune after the cams? are they 280's? AC on or off? possibly vacuum leak or just hte lack of vacuum from larger cams. don't put the car in neutral, downshift through all the gears.
Old Dec 17, 2007 | 02:36 PM
jenx1976's Avatar
cams are 264/272 and tuned., have the cams in for over 10k miles with no problems., also have a APS twin vent diverter valve.,also been in the car for about 5k miles with no problems., the issue started this morning..it was really cold about 24 deg out., when i first got in the car kindda hesistated to start. sorta like when the battery is dead., but when it finally started, it was fine until i started moving. SEL is on but thats been on for a few days now for a random misfire code., gonna reset the light and see if it comes back on with a diff code., also if there is a vacume leak, what kind of reading would i see on the boost gauge?
Old Dec 17, 2007 | 02:40 PM
JordanS4's Avatar
if you had big leak you'd know it. 2k rpm idle when warm, boost gauge around -10 instead of -17 or -18. Smaller vac leak wouldn't cause big stalling problems like you are describing but you would see it on a gauge (less vac obviously). sounds like your tune needs a bit of work, as well as your driving technique. don't drop it in neutral and cruise up to a light, stay in gear.
Old Dec 17, 2007 | 05:32 PM
jenx1976's Avatar
so my boost gauge reads between -5 and -10 on warm idle. but rpm is normal about 1000-1200....altitude here is about 4500ft and temp is between low 30's to high 40's F.....the SEL hasnt come back on yet so i cant take it to get it checked.....ticking sounds is almost like something is loose inside the valve cover., im gonna take it off and have a look i guess., if it is a vacum leak, can i isolate it the same way as a boost leak???,
Tim2s3
10
May 29, 2011 02:10 PM
alpix715
Aug 30, 2010 03:13 AM
Kracka
Oct 3, 2009 04:13 PM
Tim2s3
Sep 11, 2009 11:07 PM
03SilvaEvo
Jan 31, 2008 08:23 PM
