Greddy PRofec B Spec 2 problems
Old Dec 20, 2007 | 11:17 PM
MikeIsBoosted's Avatar
Hey guys, I had a friend of mine help me mess around with my Greddy profec b spec 2 ebc because I had no idea on how to work it. The problem is, is that he says that the settings and a few other things are different from any other profec b spec 2's he's used/seen.
Like the way you can set gain, you are supposed to be able to go from 0-100% but it only goes from 35-75. And gain set should be 0-100 but it goes up to like 250.
Is there different versions of the spec 2? I bought the car used and it came with it already installed. I've always used MBC's so an EBC is a little different for me.
Another problem we had was that it was surging when building boost. Even though it might just be a boost leak, the only way we were able to stop that was to lower the boost %, which I didn't really like.
Anyone ever hear of this? I bought a Hallman mbc a while back that I have sitting in my room. Is it time to switch over?
Thanks!
Old Dec 20, 2007 | 11:19 PM
555R's Avatar
look up the thread on how to tune the profec so you dont blow your motor...its a bit confusing but read the instructions carefully
Old Dec 20, 2007 | 11:24 PM
No, the car runs fine, minus the surge sometimes. The car was tuned by TTP.
Old Dec 21, 2007 | 09:22 AM
asr10 user's Avatar
I dont like Greddy Products. Im running the e-01 and while it works, I just dont like it.
Old Dec 22, 2007 | 06:12 PM
Shaun@AWDMotorsports's Avatar
i got a greddy profect b spec II and that thing is great i make full boots (22psi) at 3000rpm and hold it all the way to 7300rpm
Old Dec 25, 2007 | 06:33 PM
Evoryder's Avatar
it's probably the user not the unit. My greddy profec b II worked flawlessly.
As mentioned, check your settings and adjust per the instructions in the how to thread.
TitanMotorsport
Vendor Classifieds
29
Jun 23, 2014 02:21 PM
TitanMotorsport
17
Oct 14, 2013 03:09 PM
SiLLyEVO
Aug 19, 2010 09:36 AM
blanknotice
Oct 9, 2009 11:47 AM
janvin21
Sep 24, 2008 02:22 PM
