Clutch pedal doesn't fully return to resting point?
I've noticed that for the last few thousand miles my clutch pedal sometimes doesn't come all the way back to the engaged position and i have to put my foot underneath it and nudge it back up. It doesn't do it when I take my foot off the pedal quickly so it can move quickly into place, only when I do it slowly.
It sticks about 1/2"-1" from it's rest position. The clutch engages/disengages and shifts fine, but am constantly pulling the pedal up with my toe.
I bled the clutch thinking that would solve the problem...and it did for about two or three days. Now its back to pulling the pedal up with my toe again. One thing I did find strange is after opening/closing the bleeder valve, the clutch pedal stayed to the floor when my wife released it. I had to pull the pedal up with my hand. Is this normal or should the pedal return to its normal resting point on its own?
Anyone know what could cause the clutch pedal to stick sometimes about 1/2"-1" before it's "rest" position? It isn't' affecting driving or clutch engagement at all and the car drives fine. It's just annoying and obviously something is not right.
Might need a new slave cylinder...sounds like its sticking. Check to see if its boot is wet. Check the master where it comes thru the firewall and see if its dripping fluid as well. If so it needs to be replaced also.
Thanks for the info...I just checked and was actually hoping to see a leak around the base/boot. At least that way I would know what was wrong and could fix it, but there is no leak. Any other ideas?
Probably not bleeding it properly and you still have a nice set of air bubbles in the system.
I have both a clutch master cylinder and slave cylinder(both used but work fine) For sale. Let me know.
I don't see how I could be bleeding it wrong, but I took your advise and bled it again. It was perfect for about a week and a half, now I'm back to pulling the pedal up with my toe.
Oh yeah, and I checked for leaks; nothing.
Fireescape
Jul 4, 2016 11:18 PM
TurboRush
20
May 27, 2010 11:31 PM
06MRV8Killer
May 17, 2008 01:30 AM
woodc
Jun 16, 2005 06:46 PM
