Is this really just a 9.8 hotside?
Old Feb 9, 2008 | 09:33 AM
RREvo-8's Avatar
Ok everyone I did a search and no luck. So pretty much I wsa cleaning out my garage and found an old evo 8 turbo I bought a while back and noticed the hotside number casted on the side is 78-13010 115 The question is, is this really just a 9.8 hotside? In size it seems that way but just wanna make sure.
Thanks in advance.
Old Feb 9, 2008 | 10:56 AM
20Grockit's Avatar
what is the code on the compressor housing. it should either have a 9.8t or a 10.5t on it.
Old Feb 9, 2008 | 11:01 AM
RREvo-8's Avatar
The code ends in 9.8t on the compresor housing, but Im not sure if the person I bought it from switched out the hotside? Like I said it looks smaller than my 10.5 hotside, but I wasnt sure.
EvoDan2004's Avatar
he said he bought it used. so it may of been changed. it can be a 10.5hs while the comp side says 9.8. the hotside i be leave also says 10.5 or 9.8
Old Feb 9, 2008 | 11:03 AM
20Grockit's Avatar
yes true. just actually noticed that he bought it used. well it should also say on the hotside somewhere what size it is. good luck.
Old Feb 9, 2008 | 11:17 AM
RREvo-8's Avatar
the only numbers on the turbo are 78-13010 115, these numbers are on flange
Old Feb 9, 2008 | 11:18 AM
EvoDan2004's Avatar
i thought when i got mine it said 10.5 on it as well.
maybe the 9.8 did not say nothing and the 10.5 did.
Old Feb 9, 2008 | 11:22 AM
20Grockit's Avatar
you could try looking it up maybe on mitsubishis site. i dont know if they have technical info like that on there or not though.
eponti's Avatar
My hotside has 12 numbers stamped and the last 3 is 10.5
Old Feb 9, 2008 | 11:36 AM
RREvo-8's Avatar
called mitsubishi parts and they didn't know anything, told me to call a turbo shop ..thanks mitsubishi
Old Feb 9, 2008 | 11:38 AM
EvoDan2004's Avatar
if it does not say 10.5 then its most likely a 9.8. the 10.5 hot sides say it
Old Feb 10, 2008 | 12:11 PM
eponti's Avatar
Also i think the 9.8 is not a single flapper compaired to the 10.5.
Old Feb 10, 2008 | 12:13 PM
20Grockit's Avatar
there are twin flapper 10.5 hotsides
Old Feb 10, 2008 | 12:23 PM
sparky's Avatar
I have a 9.8 HS somewhere in the garage. I'll check it for you tomorrow when I get back home. The 10.5 HS has the numbers "105" cast onto the foot of the housing. The 9.0 housing which I just installed does not have the number "90" cast onto the housing though. So, maybe the 9.8 doesn't either.
Old Feb 16, 2008 | 08:10 PM
RREvo-8's Avatar
No luck yet? Anyone?
black_beauty
18
Jun 21, 2010 07:11 AM
Lucas03ES
Lancer Aftermarket Forced Induction Tech
May 2, 2009 08:46 AM
BlackonBlack2
Nov 6, 2007 06:28 AM
Sap12687
Mar 15, 2006 03:48 PM
EvoDan2004
25
Dec 1, 2005 09:52 AM
