272 or 280? And what injectors?
I think I have finally decided on doing a 3065 turbo in my car in a few months. The next step is cams and injectors. Will the 3065 do ok with 272's....or should I bump up to 280's which would also require springs/retainers? I'm not looking to go above 8500, and thats really pushing it. In reality I will probably go no higher then 8k rpms. BC cams BTW
Also, I still plan on running E85 since there are a few stations nearby now
With this size of a turbo + E85, should I be looking at 1600cc injectors? Or would 1000's cut it?
If your running stock ecu you can't run that big of injectors from what Ive been told. I think anything bigger than 780 injectors with 280 cams starts to get hard to tune for a good idle. I could be wrong though.
