Tips on wire tapping?
Old Jul 30, 2003 | 01:47 PM
SzuChenEvo's Avatar
I'm about to install the HKS type 0 w/ Greddy harness on my car...the last electronic install was done on my accord n i did a messy job...
Does anyone have any tips on wire tapping n on how to make the job clean? what tools do you use (kind of wire stripper?) what kind of electronic tapes or other material u use to cover up the stripped wires (what brand?)
thanks!
Old Jul 30, 2003 | 01:56 PM
3K's Avatar
3K
You could use wire tap splicers. It makes it a whole lot easier and very clean, nothing to cut just put the two wires in and clamp them together. They're like $3.00 for a pack of twenty or something like that. you can get em at any auto parts store.
Old Jul 30, 2003 | 02:06 PM
SzuChenEvo's Avatar
Thanks for the reply 3K!!! haha..I never knew those things existed...are any of the following the stuff you're talkin about?
http://products3.3m.com/catalog/us/e...er/output_html
http://www.markertek.com/MTStore/pro...eItem=65-1280C
http://www.circuitspecialists.com/level.itml/icOid/7449
(There are three kinds on that last website...whats the difference b/t those three? which one is the one we should use for a TT install?)
thanks!
Old Jul 30, 2003 | 02:17 PM
3K's Avatar
3K
Wow, I didn't know they had so many different types of wire taps.
I used the 18-14 AWG for my TT install, it works fine.
You can get them from any auto parts store.
Old Jul 30, 2003 | 04:59 PM
timzcat's Avatar
They come with the TT, that is what those red things are.
Old Jul 30, 2003 | 05:01 PM
timzcat's Avatar
thanks!
That third one is an IDC splice for phone wire.
Old Jul 30, 2003 | 05:12 PM
SzuChenEvo's Avatar
haha my bad...shows how much i kno
Old Jul 30, 2003 | 05:25 PM
timzcat's Avatar
Just giving you a hard time.
Did you get the ones included with the TT?
You close the 2 all plastic pieces first and the then part with the metal hinges over. Plier to get it clamped shut well.
Old Jul 31, 2003 | 10:58 AM
SzuChenEvo's Avatar
ha i haven't even open the boxes yet...but im sure they are there...thanks!
Old Jul 31, 2003 | 11:25 AM
HobieKopek's Avatar
Just out of curiousity (since I'm a complete electrical n00b) what constitutes high or low voltage for these things? I want to go back and check the install on a few things including my alarm and EGT.
Old Jul 31, 2003 | 11:53 AM
timzcat's Avatar
I don't get the question exactly but it's all relative really.
On a car it is all 12V unless it's sensor wiring (ECU) then it is usually on 5V. IN that respect you could call 12 high and 5 low but there is not much difference. Both levels can use all the same electrical supplies like taps, fuses, wire, etc...
The only high voltage stuff is the ignition coils and park plugs wires at up upwards of 80,000 volts. Of course that is why a spark plug wire is so insulated. The actual conductor inside is 1 or 2 mm.
Old Jul 31, 2003 | 12:12 PM
HobieKopek's Avatar
I meant, the red splicers were made for "low voltage" and I can only assume that means the blue splicers are for higher voltages. Like I said, I'm a complete n00b, but tryin' to learn.
Old Jul 31, 2003 | 12:20 PM
timzcat's Avatar
It's interesting they call them low voltage.
The colors are cordinated to wire size. Red is the smallest 18-22AWG, Blue is 14-18AWG and Yellow is 10-14AWG.
I think it just says that because it is a stand style small gauge tap. Some taps are sealed and of different styles. The red ones aren't like the top of the line but they are fine for just about anything automotive.
Old Jul 31, 2003 | 02:00 PM
2Cool's Avatar
I prefer to strip a bit of insulation off the wire with an xacto blade, then solder the tapped in wire to the main. Then wrap with electrical tape.
Hate those wire splices, they are notorious for poor connections, coming loose/corroding over time, and even cutting wires.
Old Jul 31, 2003 | 02:13 PM
HobieKopek's Avatar
Soldering is the method I'm most familiar with, but I really need to be more familiar before I start soldering my car's electrical system. I'm not confident enough to do that at this point.
Oh, and thanks, timz. That's exactly the answer I was looking for.
rm4g3d0n
Oct 5, 2015 07:29 AM
blakroyal
Feb 2, 2012 10:44 AM
Tokuisport
Sep 27, 2010 05:09 PM
mahunc
15
Aug 22, 2004 07:42 AM
mitsuorder
15
Aug 30, 2003 11:23 PM
