What do these codes mean?
Old Mar 6, 2008 | 07:27 PM
Fuxton's Avatar
I just had my injectors installed and was retuned. Had some problems with the injectors leaking but now its all taken care of. Driving around before my CEL came on. The codes are P0172 and P0133. What exactly does that mean?
Old Mar 6, 2008 | 07:32 PM
bigric09's Avatar
how about do a search on google ?
stuevo8's Avatar
The P0172 is System Too Rich and P0133 is Heated Oxygen Sensor Circuit Slow Response [SEMSO
all of them are here: https://www.evolutionm.net/forums/sh...ad.php?t=69304
Old Mar 6, 2008 | 07:42 PM
Fuxton's Avatar
i know what the codes stand for. Im asking what has to be done. Or what is the cause of it? I should have been more specific, sorry.
Old Mar 6, 2008 | 07:44 PM
cfdfireman1's Avatar
What has to be done you ask.
You have to search, that's what has to be done.
The answer is here grasshopper.
Old Mar 6, 2008 | 07:52 PM
Fuxton's Avatar
ok i see
Old Mar 7, 2008 | 06:23 AM
bigric09's Avatar
yes, you should have been a bit more specific with what you wanted...
you need to check your injector scaling values, could be calling the system to rich code.... your front O2 could be on its way out the door as well. Clear the code, and see if they come back.
And to clarify my earlier reply... i told you to search because i thought you were simply asking about fault codes which are too easy to find on google, if you wanted to know what could be causing those fault codes, id a given you my .02, but, you really could do a little bit of research on here and see what other people have experienced with those codes and what they did to fix them.
Old Mar 7, 2008 | 10:49 AM
Fuxton's Avatar
Thanks, I cleared em last night and drove home (only like 3 miles). The light didnt come on. Right before the light had come on i had just about stalled the car but caught it. Like it pretty much shut off. I dont know if that has anything to do with it. Im still getting used to the new clutch lol
Old Mar 7, 2008 | 10:57 AM
bigric09's Avatar
that could have cause something yes.... but, i wouldnt call it a problem yet until it comes back.
Old Mar 7, 2008 | 11:00 AM
Fuxton's Avatar
aight thanks for the help man
tarheelsoldier
Mar 22, 2015 08:54 AM
Evolved X
Nov 27, 2010 08:37 PM
702RSevo
19
Jul 8, 2009 04:47 PM
yikez
19
Nov 23, 2007 05:19 AM
cityhugo
24
Jan 12, 2004 07:23 PM
