Engine Management Mounting Location
Old Jul 31, 2003 | 06:51 PM
SzuChenEvo's Avatar
I'm thinking about mounting a turbo timer, boost controller, and AF controller under the armrest cabinet...all HKS components. One obvious problem is the accessibility of this mounting location. If you notice, the armrest cabinet is not located immediately right to the driver...it is rather a little back (towards the back of the car thus driver has to twist towards the right and back for adjustments)...the visiblity of these units would be zero during driving anyways when the armrest is closed. Here are the units I plan to get in the future:
Boost controller (the screen part will be mounted somewhere that can be visible to the driver):
http://www.gruppe-s.com/HKS/hks_evc5_l.jpg
AF controller:
http://www.gruppe-s.com/HKS/hks_safr_l.jpg
Turbo timer:
http://www.gruppe-s.com/HKS/hks_tt0_l.jpg
My question is...the change of settings (crank up the boost, adjusting the AF ratio...etc) will NOT be done WHILE the car is moving right? For example...I can't adjust the boost or AF ratio while driving right? The car has to be stopped and engine on idle for any adjustments to be made...because if that's the case then there's no problem in mounting these units under the armrest.
Thanks!
Old Jul 31, 2003 | 07:02 PM
5StarSuzuki's Avatar
In Timeout
You can change these units on the fly...but you won't. Remember more boost...more fuel. So unless you really know what your doing and have a expensive a/f monitor...you can mount them out of the way. You won't need to touch them.
Old Jul 31, 2003 | 07:12 PM
SzuChenEvo's Avatar
Actually, if I get the Vishnu XEDE unit...you can control both the boost level and AF ratio right (w/ laptop and software)? If that's the case...that means I won't need a boost and AF controller right?
thanks!
Old Jul 31, 2003 | 07:29 PM
In Timeout
correct...there are alot of options... If you decide in the future to use daily driving 93 and raceday 100...then maybe a external boost controller setup is better for you...check out some previous posts...
Old Jul 31, 2003 | 07:35 PM
SzuChenEvo's Avatar
thanks for the replies 5StarSuzuki!!!!
cky3396
124
Jul 6, 2012 04:02 PM
Insidious Evo
For Sale - Cars For Sale
13
Apr 11, 2010 12:24 PM
Kami Speed
EvoX 'For Sale' Electronics / Lighting / Audio
Feb 20, 2010 03:55 PM
Gruppe-S
102
May 23, 2008 10:34 AM
Gruppe-S
Evo 'For Sale' Exterior Styling
Mar 17, 2006 04:55 PM
