How do I remove the crankshaft sprocket? *Pic*
Unbolt the crank sprocket bolt, and it will literally slide right off without any difficulty.
I will say however getting the bolt off is a bit tricky as its got about 120ft-lbs of torque on it. Some people rig a breaker bar on a jack stand and tap the starter to break the bolt loose. It does work as I have done it that way before.
Ive always used a good Ingersal air gun but Ive also always still had the timing belt on. It has a wooddrift key in the crank so it wont hurt to take the bolt out first. Im not sure if an air gun will work now since the belt is off. Good Luck
I tried wedging a wrench inside the block to keep the crank from turning while I used a breaker bar to unbolt it. No luck! I ended up buying a 700 ft lb impact and it came right off. Thanks for the help everyone.
anthonypazsd
Jan 31, 2010 03:01 AM
Rexpeed
Evo 'For Sale' Exterior Styling
35
Dec 8, 2008 09:11 PM
chetman7
Lancer How Tos / Installations
Jul 16, 2007 04:08 PM
