WHP goal question ( Evo 9)
Old Apr 2, 2008 | 07:13 PM
Boost_Inspired's Avatar
Originally Posted by RyuEvoIX
Finish all of the bolton upgrades, get Cosworth M2 cams with the revlimiter at 7800rpms, along with Methanol and you will easily be over your 400awhp mark. No point in getting a bigger turbo if that is your goal. The stock turbo will be MUCH more fun.
Edit: Also upgrade your wastegate to an FP 18psi wastegate.
hey do the m2 cams require upgraded valvetrain to run them ? also will the stock bov hold that much power or will i need to upgrade?
Old Apr 2, 2008 | 07:16 PM
spdracerut's Avatar
Forget about the Megan crap. It'll work for a while... but they'll crack eventually. To reach your goal, you'll probably want to add water or meth injection. Upgrading to a larger intercooler would help also.
Old Apr 2, 2008 | 07:17 PM
S4STIEVO's Avatar
^yes its recomended strongly
Old Apr 2, 2008 | 07:23 PM
lol the megan crap came with the car , any answers to the above question?
Old Apr 2, 2008 | 08:04 PM
RyuEvoIX's Avatar
Only if you want to rev higher then 7800rpms. The stock bov is good up to 25psi then it starts leaking. I have a forged RS bov. It holds boost great but highway part throttle is sacrificed in 4th and 5th gear a little due to the bov fluttering. You'd get used to it though, I did.
Old Apr 2, 2008 | 08:07 PM
RyuEvoIX's Avatar
Originally Posted by S4STIEVO
it would be like 405 so i shouldnt say its not going to happen but its not going to be easy.
With the proper parts and tuner it's pretty much guarantee'd. Besides nothing thats worth doing is easy.
Old Apr 2, 2008 | 08:15 PM
oh ok i read the basic info on the m2 cams on lancer shop and they said they could be used on stock valvetrain if keeping factory rev limit , just wanted to make sure they could take 7800 ok before purchasing them , gonna try and retain the factory bov for as long as i can but if I must ill get one i can recirculate. will the factory one need to be crushed at all?
Old Apr 2, 2008 | 08:18 PM
RyuEvoIX's Avatar
It can be. Ive heard of someone holding a little more boost with a crushed one but in the end you are better off upgrading to something like a forged so there's no boost leak with high boost. The forge is a recirculated bov.
Old Apr 2, 2008 | 08:21 PM
andrewzaragoza's Avatar
definitely attainable on a dynojet but u would need an alchy or meth injection plus all the usual bolt-ons. S1 should be good enough for you target hp. of course all the mods would be useless with out a good tune. either way good luck upgrading.
Old Apr 2, 2008 | 08:33 PM
ok understood , for alky or meth , do i need to change any lines up at all for the kit? and will i need to upgrade the stock injectors to reach my 400hp goal.
Old Apr 2, 2008 | 08:52 PM
RyuEvoIX's Avatar
Stock injectors are fine, just upgrade the fuel pump since it's cheap. Im running 30psi with 100%meth on the stock fuel pump but I don't have cams yet either so...like I said it's cheap so upgrade to the walboro.
Old Apr 2, 2008 | 09:02 PM
kool thanks alot for the info man , ill look into the meth kit and sew what all info i can find and windshield washer fluid contains methanoyl correct?
Old Apr 2, 2008 | 09:03 PM
CarbonKrazyEvo9's Avatar
Originally Posted by Evo2wIsh4
Meth Injection is your friend.
Felix were have you been!!!! yes meth will take care of that for you
Old Apr 2, 2008 | 09:30 PM
RyuEvoIX's Avatar
Depending on the brand, yes it is supposed to be pretty much a 50/50 mix. Or you can purchase 100% meth and distilled water to make your own mix. Personally i'd feel more comfortable mixing it myself to insure there are no contaminants.
Old Apr 2, 2008 | 09:33 PM
ya i agree , i'd rather mix myself also , thanks again for all of the info.
