E85 481whp Stock ECU and IX turbo
Old Apr 9, 2008 | 02:09 PM
  #31
Lucas English's Avatar
I will be doing it with ECU flash. For Crag at Spark tech I will be running his ignition on Stock ECU for a little while to see how it does.
I just put the 1200s before lunch. The fuel pressure was 62psi out the top now its 56psi so I need a 2nd pump for sure.
Old Apr 9, 2008 | 02:14 PM
  #32
slicedbreadno2's Avatar
Crazy power out of a IX turbo.
Old Apr 9, 2008 | 03:00 PM
  #33
mplspilot's Avatar
So i wonder why don't more people run hi-comp pistons with smaller turbos like green?... Looks like it's the ticket. Big power and fast spool.
Old Apr 9, 2008 | 03:02 PM
  #34
dsmfan95's Avatar
I've been debating back and forth about doing this with a friend of mine. Hopefully, funds allowing, I want to try something like this this winter.
Old Apr 9, 2008 | 03:04 PM
  #35
mplspilot's Avatar
I say you and boys at ETS need to start making dual pump setups for evos. There's only 2 vendors doing it (one wants too much mula and the other is backordered i believe), and market is there, with more and more people using ethanol and bigger than stock turbos!
Old Apr 9, 2008 | 03:06 PM
  #36
HondaFlyBy's Avatar
wow u ,ust e a good driver with that good of a time..
Old Apr 9, 2008 | 03:25 PM
  #37
Tarmacisback69's Avatar
why e85? and not like alky. wouldnt u see more tq? and it would take less from the injectors aswell.
Old Apr 9, 2008 | 04:08 PM
  #38
Jim_Patterson's Avatar
Awesome work Luke. Your setups always amaze me.
Old Apr 9, 2008 | 04:14 PM
  #39
evoPirate's Avatar
Why have to have 2 maps always available in case you're out of alky and can't get a refill, when you can have just 1 map/tune for something that comes out your gas tank?
Old Apr 9, 2008 | 04:29 PM
  #40
9sec9's Avatar
Its not very thick but better then the plastic ones that melt out.
http://www.gizzmoelectronics.com/Pro...itsubishi.html
Is the plastic one you're talking about the Hondata gasket?
Old Apr 9, 2008 | 05:31 PM
  #41
jpetro10's Avatar
On the street this thing is feels nasty. I love it. In the rain with just a roll in 2nd it will always light up all 4 tires and the tach will sit at 8k till the car catches up.
I can vouch for this, lol. I got my Evo done up by Lucas this week ( which feels SICK!) and the first ride he gave me in his car I wasnt expecting anything as he shifts from 1st to 2nd all normal, then out of no where the car feels like its just hovering!!!! It felt like it was still happening half way through 3rd. This car just feels amazing.
BTW Lucas, that tune is insane. The car feels SOOOO much better, thanks again man!
Old Apr 9, 2008 | 06:54 PM
  #42
casper980's Avatar
Originally Posted by blueG60rado
What is your injector duty cycle? How close are you to needing a second fuel pump? That is badass!
AMS and others have stated that the stock fuel system with walbro 255l and proper injectors, is capable of supporting up to 700whp. No fuel rail, FPR or twin pump setup required. However if your road racing and worried about running out of fuel in the twistys then go with a surge tank and second fuel pump. For above 700WHP (650 to be safe) The Buscher twin pump set up is nice. Then you would need the fuel rail and FPR; also might think about upgrading to SS braided lines at that point. This is all from what I have been told; please correct me if I am wrong.
Old Apr 9, 2008 | 07:16 PM
  #43
JohnBradley's Avatar
Thats on gasoline, the requirements for E85 and E90 are significantly increased.
Old Apr 9, 2008 | 07:30 PM
  #44
10sectalon's Avatar
500 would be sick
Old Apr 9, 2008 | 07:58 PM
  #45
03whitegsr's Avatar
Did the throttlebody increase boost at all or does this jump in mid-range torque appear to be a VE increase?
I wouldn't have expected gains in the midrange like that with a larger throttlebody unless it just reduced the pressure drop across the throttle plate and ended up increasing the peak boost.
