Zaklee shifter bushing install?
Installing Zaklee under hood shifter bushings, Installed the lower cable bushings, reinstalled washer and cotter clip. There is alot of side to side play, compared the top Zaklee bushings with the stock rubber ones and the stock ones are wider (taller) because of 4 little **** on each side and the metal spool is also wider (taller) the same height as the ****. Two stock washers bring the Zaklee to the same width as the stock ones, so I would need three washers per cable. Is this what I need to do? Says there a perfect fit but there to narrow.
