evo9 10.5 turbo
Old Apr 25, 2008 | 05:39 PM
W2J's Avatar
W2J
evo9 10.5 turbo
what is the sweet spot for this turbo? I currently have this on a 8motor and run 19psi and I find it very laggy compared to the orginal 16G it had. any advise would be appreciated.
Old Apr 26, 2008 | 09:47 AM
TKEVO's Avatar
Veteran: Air Force
Alot of people up here have used a IX turbo on a 8 and have made some impressive numbers
Old Apr 26, 2008 | 04:22 PM
IDRNKV8's Avatar
I think its more limited than laggy. Before I get bashed with dyno printouts of high-hp stock turbo Evo 8's, im just sayinnnn.....
Old Apr 26, 2008 | 04:25 PM
IDRNKV8's Avatar
Hahaha, misread it. Thought u were talkin about an evo 8 turbo
Old Apr 26, 2008 | 07:23 PM
sparky's Avatar
You can try a couple of things. First, which also happens to be cheapest and easiest, is to increase the preload on your wastegate. Secondly, you could swap the 10.5 exhaust housing for a 9.8 unit. These should be relatively cheap used. Maybe you just happen to have one lying around from your old turbo.
Jim in Tucson
May 29, 2008 10:45 PM
ralliartboy9889
Feb 10, 2007 10:46 PM
3000ways
23
Mar 9, 2006 01:12 PM
splurge3188
Feb 9, 2005 05:07 PM
