wideband info
Old Apr 28, 2008 | 08:33 PM
slowboyy06's Avatar
wideband info
I have been faking the funk for while on this subject what the purpose of a wideband every thread. every meet i goto i here wideband 02 what is it, what does it do and when do you know its time to get one
Old Apr 28, 2008 | 08:36 PM
Wicked E's Avatar
Old Apr 28, 2008 | 08:44 PM
justboosted02's Avatar
First, SEARCH next time
the wideband lets you know the ratio of air to fuel in your exhaust stream, this tells you how lean or rich your car is running.
you need a "wide" band because it has the resolution to tell you mixtures ranging from ~9:1 to ~22:1
your car comes stock with a "narrow" band which only tells if you are either rich or lean with respect to an afr of 14.7:1 afr.
why 14.7:1 afr you ask? this is the stochiometric afr that give you complete combustion of fuel (theoretically), and therefore the cleanest emissions
Old Apr 28, 2008 | 08:46 PM
SloRice's Avatar
Originally Posted by Wicked E
Come on now...we all started somewhere.
A wideband O2 sensor is an Oxygen sensor you put your exhaust. It measures what the air to fuel ratio is the engine is running at.
If you don't have enough fuel, you get detonation or pre-ignition where the fuel in the combustion chamber auto-ignites without the spark plug firing. This sends little "shock waves" through the combustion chamber that end up hitting the "shock wave" created by the spark plug, creating cylinder pressures exponentially higher than what the motor can handle. Continuing this process will eventually kill your motor.
If you have to much fuel, the car will usually misfire or sputter because the additional fuel is putting out the spark created by the spark plug. It also makes carbon build up on the piston top and cylinder head which can lead to hot spots, which cause detonation/pre-ignition.
There is a lot more to it than that, but that should get you started.
Old Apr 28, 2008 | 08:48 PM
4WS Tuning's Avatar
its the best way to monitor your motor, as far as why you should have one...
Cheers!
Old Apr 28, 2008 | 09:55 PM
slowboyy06's Avatar
thanks for the help now im considering getting one once i get tuned
Old Apr 28, 2008 | 10:23 PM
dxbevo9's Avatar
does anyone know the conversion between the Lambda reading and the standard (9.0:1-->22:1) scale?
Old Apr 28, 2008 | 10:28 PM
dxbevo9's Avatar
ok maybe i should put it that way...
my innovate is not working for some wierd reason...so i hooked up the motec lambda reader...it reads anywhere between ( 0.88->0.93 )
is that safe or not ??
(i tried searching...i swear to god you dikheads )
Old Apr 28, 2008 | 10:39 PM
so your running between
12.9:1 to 13.6:1
richen that bish up!
that is assuming you are using gasoline
Old Apr 29, 2008 | 06:12 AM
SloRice's Avatar
A Lambda of 1 = 14.7AFR
So...
Code:
AFR    Lambda
20      1.36
19      1.29
18      1.22
17      1.16
16      1.09
15      1.02
14.7    1.00
14      0.95
13      0.88
12      0.82
11      0.75
10      0.68
9       0.61
Old Apr 29, 2008 | 06:31 AM
Chemwarrior's Avatar
12.9:1 to 13.6:1
I think you mean he needs to lean it out. If he is getting 12.9 to 13.6 on idle then he is too rich. Idle should be at stoich (~14.7).
Old Apr 29, 2008 | 07:13 AM
SloRice's Avatar
maybe they are talking about WOT???
Old Apr 29, 2008 | 07:43 AM
I was assuming that was WOT operation
Old Apr 29, 2008 | 11:46 PM
dxbevo9's Avatar
yes that is at wot...at idle its about 0.98 lambda..
but whats dazziling me is that i have 0 knock!! how come i am too lean?
hachansoo0413
Oct 19, 2013 09:48 AM
Uscbryan
22
Apr 4, 2012 03:43 PM
4bangn
10
Jan 12, 2012 10:19 AM
vivac2
Feb 18, 2010 12:26 PM
slvevo8
31
Aug 28, 2008 07:48 PM
