bore size and piston clearance
Old Apr 29, 2008 | 06:44 PM
JC evo1's Avatar
Im in the process of rebuilding my EVO1 motor, there a few issues that i would like some opinions on. The motor has been rebuilt by the previous owner but i have torn it down to fix it.
1. the head is o ringed and runs a copper gasket, problem is the moron whoever cc'd the chambers has got a bit carried away with the grinder and removed too much metal in one spot. The o ring is very close to the edge of the chamber, i have to take measurements with the correct bore size to see if the gasket will seal properly. IF the head hadnt had alot of money spent on it porting it i would turf it.
2. the bore is at 85.8, will i need to use a 85.5 piston or go to a 86? what will my PTW clearance be in thou if i use 85.5 pistons? How safe is it to bore a 7bolt)2G block to 86mm?
3. if i go to a 86mm piston, what will my bore size be in mm including clearance?
4. If i do need to go to a 86mm piston, i have concerns the head gasket wont have enough sealing area for the o ring. because of the bigger bore size.
pic of the head
Old Apr 29, 2008 | 07:03 PM
2k4EvoVIII's Avatar
Going to depend on the pistons that you decide to run. Some company's want a really big PTW clearance. I would stay away from those ...Ross...Cough.... Anyway JE are really good and Wiseco is good for the price. Talk to the company's that you are going to get pistons from. They will ask how much boost you plan to run and what the HP goals are. They will then tell you what a recommended PTW clearance is. On the last engine i built 4G64 with 87mm pistons with Wiseco's i believe it called for a 5 thousands clearance to give you a idea.
Chris
Old Apr 29, 2008 | 07:17 PM
JC evo1's Avatar
so is 5 thou written as .0050 inches?
Old Apr 29, 2008 | 07:28 PM
crcain's Avatar
Yes.
And 5 thou is in mm....
.005" * 25.4 = .127mm
Old Apr 29, 2008 | 07:44 PM
JC evo1's Avatar
ok thanks. So for a 86mm piston running .003 clearance the bore size would be about 86.08mm?
Old Apr 29, 2008 | 07:46 PM
JC evo1's Avatar
Chris
what were the power goals and use of this engine?
Old Apr 29, 2008 | 08:00 PM
2k4EvoVIII's Avatar
10K+rpms and 45psi around 850whp.
But like i said it depends on the pistons that you decide on. Not all pistons are made with the same material. Some piston manufactuars pistons calls for allot more clearance some call for less. Just depends on how much the material is going to expand when heated.
Chris
Old Apr 29, 2008 | 08:24 PM
JC evo1's Avatar
im probably going to go with wiesco's as they make an off the shelf 86 in 9:1. My engine builder sugests to use around 0.003. The goals for the engine are whatever power the 35r can make full tilt, around 9krpm max. This is a weekend only street car.
Old Apr 29, 2008 | 08:36 PM
2k4EvoVIII's Avatar
Okay with Wiseco's call this guy. He is the main man as Wiseco for the import pistons. Tell him what you want to do and he will tell you everything you need to know. If you get all the right parts and everything is working good together you can make 600-750whp with the 35R
Brian Nutter
800-321-1364
or
800-445-7334
Good Luck with your project!
Chris
Old Apr 29, 2008 | 11:27 PM
CO_VR4's Avatar
The head could be welded and remachined in the spot you circled.
Old Apr 30, 2008 | 05:46 PM
JC evo1's Avatar
is that safe?
Old Apr 30, 2008 | 06:35 PM
evoracingstar's Avatar
dangg!
Old Apr 30, 2008 | 06:36 PM
CO_VR4's Avatar
is that safe?
Yes, and it is commonly done to repair aluminium head damage.
Old Apr 30, 2008 | 06:56 PM
JC evo1's Avatar
even in the combustion chamber and on a performance engine? Imagine the damage if the weld failed...
Old May 1, 2008 | 07:15 AM
CO_VR4's Avatar
Yep. Google it if you want more detailed info.
nomnom
May 30, 2017 05:58 PM
evolve_VIII
Apr 8, 2016 12:49 PM
Tray@Forged
EvoX 'For Sale' Engine Internals and Drivetrain
Feb 11, 2016 08:15 PM
jameswwt
Aug 30, 2010 01:15 PM
maperformance
Oct 14, 2008 04:14 PM
