*help* possible fuel cut out in MR
i have a 2006 evo mr with a couple bolt on modifications such as
megan turbo back exhaust
down pipe
o2 housing
upper and lower intercooler piping
injen intake
greddy type RS blow off
so now my problem is,
when i full throttle it, it pulls very hard until i hit 6,000 or just below 6,000RPM
and then it just feels like i hit the redline but i still have another 1,000 rpms to go...
it didnt do this when the car was stock. it just recently started happening when i put all the modifications on.
im thinking its a fuel cut out but thats only a guess.
also it doesnt do that when i just ease into the high RPMS... i can ease it into Redline and not have any problems. its only when i full throttle it.
so what my question is, what exactly is going on and how would i go about fixing the problem?
thanks for the help.
down pipe
o2 housing
injen intake
the bov is recirculating and I'm aware at this point that I need a tune. But, do i need anything such as an upgraded waste gate or a fuel pump as well? or maybe even a boost controller for over boost? Once again all help is appreciated since I have had this issue for months.
Contact Chris at Mellon tuning, he is a vendor on this forum. Also I would highly recommend a Walbro or similar fuel pump upgrade just to make sure you don't run into a fuel volume issue as you continue your trip up the Mod road!
www.mellontuning.com
Package A or B would be fine for you for now.
Hope this helps
Josh
Hope this helps
Josh
Josh
hey thanks for the support Josh, that's very cool of you.
DDirtrider33 give me a shout if you have any questions about he process but I have a video tutorial on the website that should get you up to speed.
thanks for your interest
