Ams Evo Cam Test
Old May 11, 2008 | 02:01 PM
  #166
Zeus's Avatar
Soooooo I'm laid up after surgery with exposed pins in both feet... anyone want to PM/email me as to the results of the FP4's? I can't drive, nor ride any of my bikes for 4-6 weeks. Unless someone loves me, it's not like I can run down and pick up the rag.
Thanks for the PMs guys
Old May 11, 2008 | 05:10 PM
  #167
EVOhead's Avatar
AMS guys,
Any chance to see the torque graphs for the better cams?
Old May 12, 2008 | 12:02 AM
  #168
Gadiel@Big Valley's Avatar
I just buy the new Turbo mag an theres the FP4 review.
At 22psi this cams make 465whp with almost similar stock spool up and better top end than HKS 272.
Old May 12, 2008 | 12:14 AM
  #169
deleted
Old May 12, 2008 | 01:55 AM
  #170
JC evo1's Avatar
nice, hopefully thats what the s2's do as well asi just bought some
Old May 12, 2008 | 08:29 AM
  #171
crcain's Avatar
Martin, can you tell us what cam gear adjustments were needed to get each cam to the spec of the manufacturer?
Old May 12, 2008 | 08:43 AM
  #172
GregGSC's Avatar
nah we did better than that
Old May 12, 2008 | 08:47 AM
  #173
crcain's Avatar
Hi Greg would love to see what you've found.
I know when we degreed my friends Revolvers, we had to go 11 CAM degrees over to make up the over 20 crank degrees the intake cam was off.
Old May 12, 2008 | 12:18 PM
  #174
evolved83's Avatar
where is the next graph?
Old May 12, 2008 | 03:59 PM
  #175
JC evo1's Avatar
BOOYAH!!
Old May 12, 2008 | 04:04 PM
  #176
AutoMotoSports's Avatar
Martin is out of town right now but we are going to do our best to get an update up here tomorrow.
Eric
Old May 12, 2008 | 09:53 PM
  #177
Turbo Kyle's Avatar
nice work
Old May 12, 2008 | 11:20 PM
  #178
alan678's Avatar
Any luck on seeing some Cosworth M1 or M2 cam results?
Old May 13, 2008 | 12:13 AM
  #179
SRT-TO-EVO's Avatar
Cosworth wasn't in the test.
Old May 13, 2008 | 10:04 AM
  #180
alan678's Avatar
Gotcha....but that doesn't mean that they CAN'T be tested.....hopefully one day
With the Evo VIII Cosworth M2's (which have a 280 duration and an 11.0mm lift on both cams) the results should be pretty good in comparison since similar cams are used by most Evo IX owners....lets get the VIII owners some similar 'dyno proven' results
Evo VIII Cosworth M2 Spec sheet...
http://www.cosworth.com/uploads/1147891526.pdf
