Hks Dli-2
Old May 9, 2008 | 12:37 PM
sabastian458's Avatar
Hks Dli-2
I think this is the right forum.
I have a HKS DLI-2 and I dont know if it is working correctly. I have been looking for a manual for 3 hours and cant seem to search for the right thing.
Does anyone have one or know where I can download it from?
Old May 9, 2008 | 01:08 PM
bump.
Does the led on the side of the box suppose to be lit up all the time, or is suppose to be off?
Old May 9, 2008 | 01:47 PM
help?
Old May 11, 2008 | 07:08 PM
does anyone know if the light on the box is suppose to be on or off?
does anyone also know how to test the box to see if it is working correctly?
Old May 11, 2008 | 08:13 PM
psphinx81's Avatar
the light on the box should be on all the time while the car is running, make sure the unit is grounded well.
Old May 12, 2008 | 12:15 PM
I have it grounded to the same ground that is coming off the Intake manifold and bolted just below the strut brace.
Anyone know how to test the box?
Old May 12, 2008 | 12:50 PM
Gusl's Avatar
The red light needs to be on all the time.
Is the car not turning on or is it mis fireing?
Old May 12, 2008 | 12:53 PM
Well the Box is designed if it goes bad that the stock coils will still work. The reason I believe to to be bad is that 1) the red light isnt on, 2) the car ran sorta rough with it hooked up, but when I remove it from the coils, the car runs smoother thru the RPM.
Old May 13, 2008 | 11:27 AM
will I called and left a message with the HKS USA tech help line. Hopefully they will call me back.
Old May 13, 2008 | 11:32 AM
Philthy748's Avatar
If the LED isn't on when the car is running, you have a bad box...
Old May 13, 2008 | 11:47 AM
I have been trying to get some kind of testing info to verify this. But there isnt any.
Old May 14, 2008 | 06:14 AM
Ok I found out my issue. Part of it was the ground. I had it grounded to the same ground that comes off the intake manifold and bolts just below the strut brace. The second part of the issue was where I had the box mounted, it kept going into a thermal protection or something.
So I moved the ground to directly on to the battery and the red light is very bright now. Then I relocated the box to between the battery and the fuse box.
yellowevo82
May 13, 2009 07:05 AM
got boost??
May 21, 2008 12:51 PM
Noogles
67
Sep 20, 2007 10:37 PM
mrcox
Aug 28, 2006 08:30 PM
Yaroslav
11
May 6, 2006 11:38 AM
