whats the best spark plug to get?
Old May 25, 2008 | 04:45 PM
edmundo's Avatar
Alternate spark plug for EVO IX: Denso IKH22
Old May 25, 2008 | 04:57 PM
Turbodemon's Avatar
what plug and gap is good for the 8 i have 60k on my car should i replace the wires on it also or are they pretty durable???
Old May 25, 2008 | 05:02 PM
TIBOevo's Avatar
Originally Posted by smarsenal
^+1 The IX plugs are longer than the VIII plugs. Best to use the factory NGK Iridiums that are pre-gapped.
and skinnier too! totaly different plugs.
Old May 25, 2008 | 05:08 PM
TIBOevo's Avatar
i use the ngk bpr7eix. there a step colder plug. gap at .023. i also run hks dli2 ignition amp for extra juice for the higher rpm.
Old May 25, 2008 | 05:43 PM
El.BlueEvo9's Avatar
I use and have always used stock plugs. No problem with them.
Old May 25, 2008 | 06:17 PM
SpeedJunkyz's Avatar
I can't believe this thread got that far and noone "SEARCHED" Him......this topic is all over the place......
Old May 25, 2008 | 06:22 PM
smarsenal's Avatar
LOL Yeah I was thinking that same thing!! There are some huge threads on spark plug change.
BTW, No need to go a step colder plug unless you're heavily modded.
Old May 25, 2008 | 06:31 PM
yeah and you are modded, then I say change them more often than 30k. Play it safe.
Old May 25, 2008 | 08:52 PM
06 EvoIXer's Avatar
just switched mine out for densos. car is running good. my factory ngk's were burnt bad
if your not boosting higher than stock then use the stock replacements or the denso IKH22. my tuner told me denso products run good with the evo.
Old May 25, 2008 | 09:55 PM
SILVERnSLOW's Avatar
Even though you can get the plugs pregapped it's always a good idea to check them before install.
Old May 26, 2008 | 05:41 PM
bbyevo8u's Avatar
when modded how often should i change out my plugs??
Old May 26, 2008 | 06:01 PM
bbyevo8u's Avatar
i pulled one out today to see how they looked and it was a little dark and it smelt like gas! it that normal for 16K miles?
Old May 30, 2008 | 06:49 PM
BocaShula's Avatar
I need new plugs too im right over 40k miles... need help. pm me anyone
Old May 30, 2008 | 07:05 PM
Redline-Z's Avatar
Veteran: Air Force
To the OP i see your tuned and running 330's. To me the old rule of 100hp gain = 1 step colder plugs. You should be running a 1 step colder iridium plug, you can get them from ExtremePSI and yes they cost more but the old "rules" don't lie!
Old Jun 6, 2008 | 06:34 PM
racer135's Avatar
So what is the recommeded plug for an Evo 8 with bolts on? Is it BR8EIX (Iridium) or the BPR8ES (Copper)?
