Forced Performance Evo Red Turbo data
Old Jul 18, 2008 | 05:29 PM
  #511
smokeall4's Avatar
the red turbo is pretty impressive.. it made some good power for being such a small turbo..
Old Jul 18, 2008 | 06:31 PM
  #512
smokeall4's Avatar
looks like a cool turbo good hp and nice torque
Old Jul 19, 2008 | 12:15 PM
  #513
Talonboost's Avatar
FP guys: I had a little conversation with Jeremy at PTE a couple days ago. He seems like a pretty with-it guy but he said one strange thing - He said "nobody in the world mills turbine wheels out of a billet".
So tell me, this pic posted by GrocMax, this is going to be a turbine wheel when the milling machine gets done with it, right?
Thanks,
Gary
Old Jul 19, 2008 | 12:39 PM
  #514
theshadow's Avatar
So if my HKS 272/272 cams are crap, worth replacing them to support a Red even if I have MIVEC and where would i see gains from doing so?
Also, would MIVEC tuining be able to smoothen out the spool or would the benefit be mostly at the mid-to-high end?
They'd have to be really substabtial gains to justify the cost but just askin
Old Jul 19, 2008 | 03:03 PM
  #515
CO_VR4's Avatar
Thanks,
Gary
The picture does not show a turbine wheel "milled out of billet". It shows a casting, before the machining steps are done.
Old Jul 19, 2008 | 03:37 PM
  #516
JKav's Avatar
Talonboost--
FP's comp wheels are cnc'd from billet aluminum. The turbine wheel (pictured) is cast steel which is subsequently machined & ground to final geometry.
On a design-related note I'd be leery about the cast-in logo acting as a stress riser in the turbine wheel's backdisk...
Old Jul 19, 2008 | 07:05 PM
  #517
Talonboost's Avatar
Originally Posted by JKav
Talonboost-- The turbine wheel (pictured) is cast steel which is subsequently machined & ground to final geometry.
Ok that's what I thought. Jeremy knew about machined billet aluminum compressor wheels but he didn't know anybody was making machined billet steel turbine wheels.
Yeah that pic from grocmax looks like a casting of some ferrous alloy, sure doesn't look like an aluminum casting, and it has 11 blades which would be a lot for a compressor wheel but normal for a turbine wheel.
Now if these things are ground to final geometry, that is an operation I would like to see some video of. I've seen grinding of cylinders, spheres, flats, surfaces of revolution, and ruled surfaces, but I highly doubt that the final blade shape on this thing is all ruled surfaces.
Gary
Old Jul 20, 2008 | 01:11 PM
  #518
GrocMax's Avatar
Thanks,
Gary
There ARE billet turbine wheels. They are uber expensive.
Old Jul 20, 2008 | 01:17 PM
  #519
GrocMax's Avatar
I'm gonna recant that after breaking a stock spring early saturday AM. No evidence of loft, bounce or surge but its obviously happening if a spring breaks. Keep the RPM's lower than we did with stock springs, cumulative spring surge effects over time will weaken them. I wanted to find the limits, and did.
Originally Posted by GrocMax
We've run 4R's on stock springs tagging the 8500 RPM rev limit constantly for the last 7+ months, however a set of springs is cheap insurance. Red's gonna love cams and MIVEC, especially at lower boost levels.
  #520
Erik@MIL.SPEC's Avatar
Red's gonna love a 2.4 with some Cosi M2's....ain't got no MIVEC
Old Jul 20, 2008 | 01:18 PM
  #521
sparky's Avatar
So what sort of applications are these billet turbines found in, GrocMax? Is it rally racing, Drags, custom Porshes, or what? Thanks, just curious!
Old Jul 20, 2008 | 01:21 PM
  #522
GrocMax's Avatar
Well, maybe, but the OEM's ALL grind or mill that area for balancing.
Talonboost--
Old Jul 20, 2008 | 01:28 PM
  #523
GrocMax's Avatar
One-offs, design verification etc.
The precision molds for those things are very expensive.
If you are making one or a dozen its cheaper to whittle, if you are making hundreds or thousands make the molds.
  #524
sparky's Avatar
Erik: Are you building a C.A.R.B., "legal appearing", Red-equipped, terror engine, for your Apex Silver VIII?
Old Jul 20, 2008 | 01:49 PM
  #525
CARB wouldn't like it if they knew what I was doing, but it will appear "stock" for all parties involved
Red is definitely going to be a part of things...just have to finish up some MIL.SPEC projects
