Car suddenly will not build boost at a stop
Old Jul 12, 2008 | 05:26 PM
SEEnoEVO's Avatar
I didnt think so either but i figured it was worth a shot. I wont be able to test for a boost leak for a while. I did change my boost duty start % a little while back on my AVCR. I dont know if that would do it either. I will check out that theory tomorrow. I am really lost on this one. It will go to 0lbs or slight vacuum and stay there.
Old Jul 12, 2008 | 05:28 PM
Mellon Racing's Avatar
is the 2-step working? I mean it's holding the RPM right, not just revving to the moon...
Old Jul 12, 2008 | 05:29 PM
SEEnoEVO's Avatar
That is correct. If i just leave it in neutral, and rev it, it will go to redline and build a little boost, but with the clutch in, in first, at a stop, it bounces at 5700 and builds nothing. Very frustrating.
Old Jul 12, 2008 | 05:31 PM
yeah ok, just making absolutely sure it was functioning..lots of people have problems with the clutch switch but that's not the case here.
Old Jul 14, 2008 | 04:24 PM
SEEnoEVO's Avatar
Just took a couple logs and noticed that my 2 step log only shows my throttle % at 36% while its floored yet my 3rd gear pull shows 100%. Any ideas?
Old Jul 14, 2008 | 04:37 PM
importjake00's Avatar
This is a issue I havent heard before.. interested to know how you fix it!
Old Jul 14, 2008 | 05:08 PM
woah, sounds like you found the problem...that's definitely odd. I've never heard of that. Bad TPS sensor or adjustment?
Old Jul 14, 2008 | 05:15 PM
SEEnoEVO's Avatar
but just while on 2 step?
Old Jul 14, 2008 | 05:25 PM
I know it doesn't make sense but maybe you can borrow on from another car just to rule that out so you can move on.
also try loading a bone stock ROM just to make sure there's not something in your tune causing a problem.
Old Jul 14, 2008 | 05:35 PM
SEEnoEVO's Avatar
I dont know what the hell is going on. I re-flashed it with the same map and now it seems to work fine. I will monitor it and keep everyone in the loop.
Old Jul 14, 2008 | 05:38 PM
sounds like the ROM didn't flash properly last time, did it get interrupted last time? lost power or got disconnected?
Old Jul 14, 2008 | 05:41 PM
SEEnoEVO's Avatar
Not that I know of. I am just as confused as you. I never had any wierd errors when flashing. On a side note while i have a tuning pro's attention.....i have looked up injector scaling and am somewhat lost. I am installing 850cc's with a new turbo in a few weeks, can you point me in the right direction as what to adjust for the new injectors??
Old Jul 14, 2008 | 05:48 PM
well, thats information I sell
however there's a thread on here where some people are sharing that info...some of it's terrible though likely because they were dialing in the injectors with boost/vacuum leaks or just plain don't know what they are doing
gpfury86
Jan 7, 2012 07:31 AM
EVO8LTW
13
Sep 1, 2010 07:06 AM
sky_01
15
Sep 17, 2007 11:41 AM
staxripa
19
Jul 14, 2007 09:06 AM
MR05Evo
Jun 17, 2007 04:32 AM
