Found damage in my head- is it a problem
Old Jul 14, 2008 | 08:50 PM
Kmac's Avatar
Pulled the head off today and there is some damage to the cams and cam guides. The worst of the damage is on the front of the motor on the end of head, (closest to the cam gears). There are grooves in the metal and it is pretty roughed up. I am not sure how big of an issue this is. I am wondering if I can smooth out the damaged areas and be OK. I know this his is a result from the low oil pressure that caused the bearing damage.
Old Jul 14, 2008 | 08:51 PM
sabastian458's Avatar
post pics. some grooving, depending on mileage, is normal
Old Jul 14, 2008 | 08:52 PM
vaboostn33's Avatar
Edit.
Old Jul 14, 2008 | 09:16 PM
Kmac's Avatar
I'll definitely get some pics up tomorrow. I think things should be fine, I just want to make sure I am not going to have problems with the head. I am going to be putting the head on a new AMS 2.3rr and want to make sure everything is perfect. Loosing a timing belt or something else would not be good after investing in the RR!!
Old Jul 14, 2008 | 09:26 PM
fimotorsports's Avatar
I would definitely take it to a machine shop to give it a quick look, pictures aren't going to tell the whole story. You might as well get it fully checked out by a pro before installing that bottom end.
Old Jul 15, 2008 | 08:15 AM
jmartinez1170's Avatar
Send it out to headgames they do some of the best work ive seen.
Old Jul 15, 2008 | 08:40 AM
Kmac's Avatar
Where is Head Games located?
Old Jul 15, 2008 | 08:46 AM
evilbada's Avatar
Head game is taking care of similar issue on my head.
Chronic misfire is about to be gone..
Old Jul 15, 2008 | 08:49 AM
justboosted02's Avatar
NJ i believe
JAM did my head and im extremely pleased with how it came out
Old Jul 15, 2008 | 01:22 PM
Kmac's Avatar
What was causing the misfire?
Old Jul 15, 2008 | 01:25 PM
Kmac's Avatar
How could I find out what would be acceptable on the worn down areas? What is 'Normal'?
Old Jul 15, 2008 | 01:55 PM
BiFfMaN's Avatar
well if it makes a grove to where your fingernail could catch..then yah its bad. Some cases the cam can be saved but its a long down time.
Some pics will help us for sure to determine if its a low oil issue. Plus it wouldnt hurt to check the Valve springs on a Spring compressor( I dont have the specs, the spring makers would have that), But that would ensure the springs are in good working order.
Old Jul 15, 2008 | 09:44 PM
HeadGames's Avatar
although judging in person is better, pics would be good...it can be expensive to weld, bore and hone cam journals though. Almost, if not the same cost to you as buying a good used head..
