who makes the light-es IC?
Our 3" intercooler weighs 17lbs where the stock unit is 11-12lbs IIRC. Most of the difference can be attributed to the fact that the stock intercooler is significantly smaller and uses a tube and fin core, where our 3" is larger and uses our bar and plate core. The difference in efficiency and flow is well worth the ~5-6lbs. as most customers report quicker spool/better response and being able to run more boost on the order of 2-3 psi and more timing amounting to at least 5-6 degrees on pump fuel. Consistency is another factor to consider, with intake temps barely fluctuating during repeated hard driving for autocross, time attack or road racing or a full rip through the gears (even repeated pulls) in a drag race
Tom
Tom
https://www.evolutionm.net/forums/sh...hlight=weights
the topic is interesting. For me the weight of the I/C is an indication of how easy it cools off after stayiing in traffic for a while. I remember my subaru sti suffered from a heavier I/C (APS) because it could not cool down as good as the stock STI I/C and the car knocked bad. Now the evo has a front mount but I think this principle applies in all applications.
I run and recommend the GT spec tube & fin intercooler from Hybrid power.
Core size: 24"X12"X3.1"
Overall size: 32"X12"X3.1"
Inlet/outlet size: 3"
Only ways 6.2kg! Do some reading up about it on the site, with GT35R i gained 15kw @ wheels over my bar & plate intercooler.
They also have the RS Spec which is bigger and rated to 900+ HP and only weighs 8.2kg!
http://www.hybrid-power.com/
