is there anyone who actually knows?????!!!!
What is the compression supposed to be for a evo 9
i've heard that its different from the 8 and then i hear its not
Anyone friggin know for a fact what it's supposed to be?
i know the 8 is supposed to be like 140-170 or something
Straight from the Evo 9 Service Manual:
Cylinder Compression:
Crank the engine with the throttle valve fully open and measure the compression pressure.
Standard value (at engine speed of 250 r/min): 1,000 kPa (145 psi)
Minimum limit (at engine speed of 250 r/min): 637 kPa (92 psi)
Measure the compression pressure for all the cylinders, and check that the pressure differences of the cylinders are below the limit.
Limit: 98 kPa (14 psi)
