Tial Wastegate Issue
So I had finished boost leak testing last night and went out to make a few pulls, in 2nd gear I watched the boost gauge climb to 35psi. I knew I didnt have the boost controller (Hallman) turned up that much. I figured the ball got stuck right?
I turned it all the way down so it should be off of wastegate pressure (15psi). Make another pull, same thing! So I just got rid of the boost controller all together and tried it with just the wastegate. Same thing climbed to 25psi before I let out. So I take it I have an issue with my Tial 38mm wastegate. Anyone else ever had this issue?
I was wondering If I could blow air in the wastegate and see how that goes.
But remember, I even took the boost controller off, just a line to the turbo to the wastegate and still had the same problem. I did a boost leak RIGHT before I took the car out, so no leaks.
Im at work and a lot of sites are blocked so im limited to show you here.
I found this on Google Images, its the same thing but mine is coated.
http://i26.photobucket.com/albums/c1...81/Car/rnr.jpg
you were saying it was working fine before on this setup or a different one?
