Your Opinion...
Old Aug 11, 2008 | 01:52 PM
EVOLVEU's Avatar
Your Opinion...
I just did a compression test on my car and this is what I got:
#1- 190
#2- 190
#3- 172
#4- 190
#3 looks sketchy, but there is no oil in coolant, and vice versa. What does everyone think? Thanks.
Old Aug 11, 2008 | 01:53 PM
EVOLVEU's Avatar
I know someone is gonna say "search", but Im looking for some of the "gurus" opinions on this.
Old Aug 11, 2008 | 01:56 PM
rcheung's Avatar
Did you retest that cylinder by unscrewing the guage and screwing it back in to see if you get the same reading?
Old Aug 11, 2008 | 03:52 PM
EVOLVEU's Avatar
yup, same reading. plugs look good too.
Old Aug 11, 2008 | 06:39 PM
gamebred26's Avatar
pour a cap full of oil in the cylinder and do it again see if the number comes up.
Old Aug 13, 2008 | 05:02 PM
EVOLVEU's Avatar
# did not improve after ^^^
Old Aug 13, 2008 | 05:05 PM
MuslimEvoFreak's Avatar
Sticky valves? Blown gasket around that cylinder? Worn ring?
Old Aug 13, 2008 | 06:15 PM
Evo8luva's Avatar
with my stock motor, it looked nearly identical to what you have. #3 kept going up too! between about 15k miles, it went from ~170 to 185. When i tore the motor down (after a timing belt failure) , i saw NOTHING in the bottom end that looked out of the ordinary and the head looked good, the exhaust valves were bent, but they werent gunked up or burned at all, and the intake valves looked great. Confused the hell out of me.
2 buddys of mine have 05's and they show the same thing too, i dont get it, lol.
Old Aug 13, 2008 | 06:17 PM
4G63 T's Avatar
you are fine!
Old Aug 14, 2008 | 04:54 AM
EVOLVEU's Avatar
Originally Posted by 4G63 T
you are fine!
Im going to get a leak down test done tomorrow. Ill post the results
Old Aug 14, 2008 | 06:25 AM
justboosted02's Avatar
if youre really worried do a leakdown test
Old Aug 14, 2008 | 07:56 AM
Nomad4g63's Avatar
u have a ghost in cylinder #3 call ghostbusters lol
lol nah i agree with ^^ do a leak down test for further inspection
Old Aug 14, 2008 | 08:03 AM
jmartinez1170's Avatar
If your on stock ECU your fine.
If you have a AEM have it retuned.
My #4 was down to 112 and i drove around like that for 8 months without knowing but i knew something was wrong when i would lose to other evos with not even 1/2 the mods i had at the time. Found out when they put in the AEM it was down. I said just give me a safe tune. A week or so later i hear a pop and that was that. The AEM was over tuned.
Old Aug 14, 2008 | 08:46 AM
what?
are you suggesting that a retune will increase his compression or are you saying that a poor tune is causing damage to his engine and decreasing his compression?
a bad tune will affect either standalone or stock ecu
Old Aug 14, 2008 | 09:49 AM
EVOLVEU's Avatar
stock ECU, but what he said doesnt sound right. I know most VIIIs have lower compression in cyl 3, but this is really low.
