Walbro question...should i be worried?
Old Aug 15, 2008 | 08:19 PM
SickSilverNLow's Avatar
So the past couple of days, it been super hot in my area....98 to 100 degrees and i rarely drive my evo to work. Yesterday when i went to work, the car sat outside for about 8 hours and i did the same thing today. I noticed that the car when i come home and park the car, the walbro whine is really loud, like a high pitch noise like its over-working or something. It never does this in the morning when i start the car and drive it around, just in the afternoon after work. The car does not want to die or anything and it does not feel like the car is running out of gas and stalling or jerking. The pump is only a year old. Do anyone experience this with their walbro 255 setup? Thanks.
Old Aug 15, 2008 | 08:20 PM
tripperfx3's Avatar
Mine does this too as well as others in the area when their car gets really hot, so I'm guessing thats the reason for the uber loud whine.
Old Aug 15, 2008 | 08:26 PM
^really? That loud....mine is like high pitch hissing sound.
Old Aug 15, 2008 | 08:30 PM
sparky's Avatar
Does your Walbro have the install kit? Do you usually keep your gas tank near full, or do you run it below 1/2?
Old Aug 15, 2008 | 08:33 PM
Kracka's Avatar
Walbros like to get really loud as they get hot; its common.
Old Aug 15, 2008 | 08:39 PM
yeah, it has the install kit...the car had about 1/4 tank of gas. i dont drive the car too much so i dont like to put alot of gas in the car. dont like old gas in the tank.
I wonder why! Is it due to the expansion of the gas in the tank and the pump being worked harder due to the pressure in the tank?.
Old Aug 15, 2008 | 09:09 PM
P-ROY's Avatar
mine has whined ever since the temp went up!!!
try turning the A/C on and the stereo down
Old Aug 15, 2008 | 10:23 PM
thatdudety's Avatar
mines whined since i put it in. did it on my old car too not sure why though.. also curious
Old Aug 16, 2008 | 08:05 AM
I started the car this morning and the noise was gone....drove around for a while under the cooler morning temp and no sound.....very curious on whats going on. Gonna fill up the car completely today to see if it does this with a full tank.
Old Aug 16, 2008 | 08:26 AM
Zeus's Avatar
They are called "whinebros" for a reason...
If you are afraid the pump is going out, you need to be monitoring fuel pressure and A/F.
Old Aug 16, 2008 | 08:29 AM
^thanks man. Should i check the a/f at WOT or just cruising around?
Old Aug 16, 2008 | 10:13 AM
Zeus's Avatar
Both... leaning more toward the top end...
Old Aug 16, 2008 | 10:37 AM
mnbvcxz's Avatar
mine whine's pretty loud too, i was told it was normal
Old Aug 17, 2008 | 02:41 AM
No whining today....it was a cooler day and i drove the car pretty hard.
Old Aug 17, 2008 | 02:57 AM
DxbIX's Avatar
I wouldnt worry about it, I live in the middle east and drive the car all summer, which can hit 120 degrees easy, when i get back after a drive its whining, does it all the time.
