Anyone Running FP RED YET?
Old Aug 19, 2008 | 05:17 PM
  #46
highbredcloud's Avatar
Originally Posted by ccboy37373
Im sure the Red is worth the extra $$ but we will see...
I am sure the Red is a better all around turbo...HOWEVER...on a stock motor with just basic bolt ons? I have seen stock turbos make around 350 WHP so only shy about 20 WHP vs the Green...but the difference was much more distinct with the power under the curve vs peak HP...so this could be the same case with the Green vs the Red...the Red might only make 20 WHP more peak...but could be a monster with the power under the curve...or it may not...right now there is about $700 difference between the two...lets see what happens...
  #47
JordanS4's Avatar
Buschur said from the beginning this turbo would only make 30 more whp than an equally equipped Green turbo (bolt on type Evo's, not fully built). Is it worth $700? Possibly, we pay more than that for 30 whp often times. No one should be surprised at these results and the fact that it did so well on the test mule cars comes from their level of modification and high boost/octane levels.
Old Aug 19, 2008 | 05:23 PM
  #48
Turbo Kyle's Avatar
Waiting for the graph
Old Aug 19, 2008 | 05:30 PM
  #49
hmm...it really depends what one is looking for...personally I want close to stock spool with the extra kick...hence why the Green seems to be the best choice...since it spools close to stock...I wonder where the Red actually kicks in...$700 is a lot for only 30 HP...I would like to know where the Red kicks in...and where it dies off vs the Green...someone eventually will have the graph...but for a turbo under $1K...I don't see a better alternative than the Green...anyone know how much more HP the Green makes over a stock IX tubo with bolt ons?
Old Aug 19, 2008 | 06:21 PM
  #50
kreionic's Avatar
I will go into more details after i get a shower and relax a bit
This is very much an every person evo but most have an IC this car doesnt
Here are the mods and graph
FP red
Cosworth M2 cams,
TBE
evopower mods o2 dump
Intake
stock ecu
stock IC
Old Aug 19, 2008 | 06:32 PM
  #51
EvoJoeIX's Avatar
this is going to get good
people dont understand the cbrd dyno
Old Aug 19, 2008 | 06:44 PM
  #52
BlueDemon's Avatar
I like how the torque reaches quick to its maximum point like a stock turbo, stays constant up to 6200 and then just drops a little and slowly. This is good news to me and the 02 dump is performing as expected.
Old Aug 19, 2008 | 07:05 PM
  #53
CBRD's Avatar
youre seeing alot of fp actuator holding torque (albeit holding boost)... boost is not on the plot...
the boost curve is very much a mound... because of fp's actuator, as we have seen with the green, allowing it to hold more boost to redline.
for pump gas, i think id run a green over the red, considering what ive read of this turbo, and what i saw first hand with it on the bench, it is obviously what dave b has proven... very good over 30psi... like a 35R type turbo.
on the street at pump boost levels the results may be different... right charlie?
cb
Old Aug 19, 2008 | 07:11 PM
  #54
2highpsi's Avatar
I made 420whp on the BR dyno. 93 octane only. 29psi.
It's a great turbo
edit: If I didn't have a ported head and a BR built 2.0 I don't think the results would have been as good. Not sure if I would opt for one over a green on a "bolt on" car.
Old Aug 19, 2008 | 07:18 PM
  #55
andrewzaragoza's Avatar
cb
was it able to maintain the boost all the way to redline? or was there still a little taper even with an fp actuator?
Old Aug 19, 2008 | 07:41 PM
  #56
CBRD's Avatar
it tapered very little...
id be curious to tune one on the stock ecu controlled boost, instead of an mbc.,.
cb
Old Aug 19, 2008 | 07:46 PM
  #57
kreionic's Avatar
cb
Agreed. The turbo starts to come alive at 26.5+psi. Running anything else i think the green would be a more fun turbo. All out car running high boost the red will be a good turbo. With this car on the stock IC it didnt make much sense to run higher boost. Yeah it would have made more power but for that 1 pull then heat soak. The car is getting a BR ic soon we will run some higher boost on pump to see what it does. All in all i actually expected less power at low boost with later spool. It was a pleasant suprise
How was the drive home Matt? Enjoying the car now
Old Aug 19, 2008 | 07:49 PM
  #58
cb
wow thats very good.. i bet with a 3 port boost solenoid or a good ebc that it would not taper at all. or maybe add a spring to make the wastegate hold more boost. either way those are very good results!
Old Aug 19, 2008 | 07:51 PM
  #59
FP red
Cosworth M2 cams,
TBE
Intake
stock ecu
stock IC
was the dotted line the green?
Old Aug 19, 2008 | 08:01 PM
  #60
SOEuro's Avatar
Originally Posted by Shacochis06
Results are in 379@313 94 octane....stock fmic/licp...CBRD mustang dyno
WOW,very impressive
