just did timing belt, vibration
Old Aug 24, 2008 | 10:08 AM
Henrys Ralliart's Avatar
Hey all! First of all I should tell you Im not working on an evo, just a ralliart, but I think my problem might pertain to evos too, so maybe you can help. I just did my timing belt on my 2.4 lancer and when I started it up everything runs fine, at idle. When I went to test drive it I felt some vibration in the drivetrain, even through the shifter linkage. I think its a problem with the balance shaft, but when I just took it all back apart everythings perfectly timed (theres a seperate belt for the balance shaft only). Is it possible to have the balance shaft 360 degrees off? I replaced both belts, with OEM equipment, and timing belt tensioner OEM. I should clarify, the higher the RPM and load on engine the worse the vibration is felt.
Old Aug 24, 2008 | 02:42 PM
gsrboi80's Avatar
Yea man sounds like your balance shafts are definately 180 out. Common mistake when changing timing components
Old Aug 24, 2008 | 02:44 PM
E VOL IX's Avatar
Correct the balance shaft is out.
DEA
Jun 16, 2015 04:10 PM
Henrys Ralliart
63
Mar 17, 2012 07:17 PM
gmjake
Sep 10, 2010 07:21 PM
Solley
19
Jan 15, 2010 02:57 PM
drewdq
13
Jul 17, 2009 08:12 PM
