T-3/T-4 set-up
Old Sep 3, 2008 | 06:28 AM
OhsixIXBish's Avatar
T-3/T-4 set-up
whats up guys. ive tried to do the whole search thing and couldnt seem to find nothing. Im just wondering what my car should or would put down with a t3/t4 set-up on 93 pump/ e-85 anyone with numbers and mods list? My friend had this set up on his sti and took it off because hes goin with a bigger turbo and is offering it to me cheapp! Didnt know if it would be worth it to buy it get it put on and tuned. Soo anyone out there with number please post!! thanks!!
Old Sep 3, 2008 | 06:33 AM
kim.ry's Avatar
t3/t4 are just types of manifold. what kind of turbo is it?!
Old Sep 3, 2008 | 06:42 AM
thats what he told me it was a t-3/t-4 set up thats all he told me...ill get more info on it!
Old Sep 3, 2008 | 06:43 AM
TeamValorRacing's Avatar
t3/t4 is a hybrid turbo with a t3 turbine, housing, and flange. then on the front it has a t4 compressor.
Old Sep 3, 2008 | 06:51 AM
So this would be the type of turbo...so anyone with number and how good is this turbo?
Old Sep 3, 2008 | 06:55 AM
JakeTheVIII's Avatar
As said above, a t3/t4 setup is NOT a type of manifold. A manifold is either t3 or t4... A t3/t4 is a type of turbo with a t3 pattern hotside(where the manifold goes), and a larger t4 rated compressor housing.
Old Sep 3, 2008 | 06:58 AM
Ok....any numberss???? is it a good or bad opinions...open to all..
Old Sep 3, 2008 | 07:01 AM
if its a 76 trim "P" turbine with a .63 ar. and a t04e compressor with a 57 trim wheel, it will give you around 380whp or so while still maintaining a 72-ish% efficiency rating at around 17 psi.
Old Sep 3, 2008 | 07:04 AM
jmartinez1170's Avatar
Forget what your friend is selling you and go to one of our vendor sites and get a real turbo kit. As you clearly dont know anything about turbos.
Old Sep 3, 2008 | 07:21 AM
kim.ry's Avatar
i meant to ask what kinda turbo it was. my bad
Old Sep 3, 2008 | 07:24 AM
It's not just one kind of turbo. There are a few t3/t4 turbos....
The one I've seen most often is like the one mentioned above by TeamValorRacing....T04E. Search around the internet for the T04E. He's pretty much right on about the power too...
Old Sep 3, 2008 | 07:29 AM
kim.ry's Avatar
I know there are few several t3/t4 turbos out there, but like i said, i meant to ask the OP what turbo it exactly was. cuz all turbos has diff features/characteristics
Old Sep 3, 2008 | 09:09 AM
THank dick..but ok thansk for all the input guys.
Old Sep 3, 2008 | 09:25 AM
omniprobe's Avatar
hand over your evo and give it to me.....
Old Sep 3, 2008 | 10:17 AM
Poloiceberg's Avatar
You need specifics about the turbo to have an idea of what it will make. T3/T4 is so general no one can help you without specifics
