3 ACD lights, only during hard track use
Old Sep 9, 2008 | 02:15 AM
exacc's Avatar
It the second time I got this on a trackday...but when I drive the car hard for about 6 or 7 laps, the 3 ACD lights come on, and the ACD stops working.
I cool down the car, shut it off, and the 3 lights disappear, and its back to normal again. this happened to me for the first time, the last trackday...and now it happened again.
I use the car every day as my DD and its fine, never get 3 ACD lights on at the same time on street use.
Any ideas?
TIA...
Old Sep 9, 2008 | 04:59 AM
tkklemann's Avatar
Try taking it to the Mitsu dealer and have them scan the four ABS sensors along with the two G-Force sensors.
If you have a factory service manual, you can pull the big connector from the ABS motor (On Firewall, Passenger side, Inside engine bay), and probe the connectors for each ABS sensor to see if you have continuity. I found a broken wire in my car, the ABS sensor on the front drivers side wheel. It was intermitent, and would go away whenever I washed out the engine bay because the water would cause enough contact to make the lights go away.
The wires to probe, at least for the ABS are:
29 and 30
22 and 31
8 and 9
6 and 7
This probing will tell you if your ABS sensors are all working.
Is your ABS light on? If so, you can check for a DTC code and it will tell you what it is seeing as a fault. You can check for a DTC by (Copied straight from manual):
1. Use special tool MB991529 (AKA, Paperclip and wire) to ground number 1 terminal of the data link connector (OBDII Connector).
2. Depress the brake pedal and hold it.
3. Turn the ignition switch to the "ON" position.
4. After turning the ignition switch to the "ON," release the
pedal within three seconds. Repeat this process of pressing
and releasing the brake pedal 10 continuous times.
5. Turn the ignition switch to the "LOOK" (OFF) position.
6. Disconnect special tool (Paperclip & wire)
What this will do is flash the ABS light and read out the DTC to you using the ABS light in the car.
EDIT: Shoot, I see you have an EVO VII, so this might apply to you. I am not sure if the layout of the VII's is the same. THis was from a manual for an 05 VIII.
Old Sep 9, 2008 | 10:13 PM
exacc's Avatar
Hey thanks! I will just try to have them scan the entire ACD system. I already had a 3 light problem before and it turned out to be an ABS sensor on the front right of the car. Replaced that and the light never came back. Its really only during hard use that I get it...so I am trying to find a solution or a reason why that is so. Do it overheat or something? Anyway, with these things, its really hard to find out without scanning it anyway, so I will do that...thanks!
Old Sep 10, 2008 | 08:52 AM
2006blkevo9's Avatar
I had the same problem while driffting. The acd was getting to hot, causing the ACD not to work. Well, when i say not to work i only mean that the lights are all on so the pre-set settings don't work, but it still works. I switched to a better fluid, im not to sure which one, i don't remember. But i had the stock fluid in there orginally and I have not had a problems since
Old Sep 10, 2008 | 08:55 AM
srtboostin22's Avatar
my car ha all 3 acd lights on the other day.. first time since i got my clutch put in.. they put redline in there so, hopefully it has nothing to do with the acd overheating.
Old Sep 12, 2008 | 08:18 PM
exacc's Avatar
Yup, sounds like the same problem I have...Did you say you were using the stock fluid, when it overheated?
What Fluid are you using now? Very curious to find out...
I am using Royal Purple MaxATF fluid, which says its good for Dextron III applications...I will try to find stock fluid, to see if that will work better for me. For some reason, it is so hard to find the standards that ATF uses...not sure if Dextron III is equal to SP III.
Old Sep 13, 2008 | 03:27 AM
Mellon Racing's Avatar
if you're getting the lights after a clutch job that's likely either low fluid or it's got air in the system and needs to be bled.
killerpenguin21
Jul 11, 2018 10:41 PM
al3lwan
Jan 31, 2014 10:29 PM
HN7
Jul 28, 2011 01:18 PM
19DB794
12
Sep 9, 2010 07:15 AM
zeus1
19
Jun 14, 2009 09:32 PM
