Installed ETS FMIC now some issues.
I've been having the same issue however I am tuned. I am running the ETS 3" intercooler with lower and upper intercooler pipping, ETS Mass Air Intake System, Buschur Racing Inline Manual Boost Controller, and Stock BOV.
When Im cruising in 5th gear and my boost is at 0-5ish I get a fluttering and sometimes it feels like the car is being pushed backwards a little bit. I'm trying to figure out what is causing it but Im not to sure. Any ideas?
i have that also but not too worried about it.i read somewhere you put nipple on hot side ic pipe and run bov off there and surge will be gone.
Everyone's default answer on EvoM is to blame it on the tune or lack there of lol. Jose I would connect the little line from the stock boost controller back to the intake. I am not sure if you are running a mbc or not but if you are not then just connect it back the way it was on the stock snorkal. If you are running a mbc then connect the one line from the stock selonoid and cap the other one. That is what I did. I have no issue with idle or stalling in low rpm and my bov is venting
Edit: If you decide to go get a flash some where let me know. I want to get one too. I am considering a mellon mail in flash at the moment since I already have a tactrix cable.
-Remy
-Remy
