Humming Sound
Old Sep 19, 2008 | 03:16 PM
EvolutionRus's Avatar
Humming Sound
I just recently picked up a 2003 Evo 8 with about 70,000 miles on it. I noticed when i got it, it makes alittle humming noise at idle and starts to have a slight "tick" when im just cruisin. Its not coming from the engine, but when i push in the clutch, it stops. Ill let out the clutch and it starts again. Any clue what this could be? I was thinking possible throw out bearing problem or somthing similar. The clutch still is still very stong, smooth shifting, and it doesnt grind any gear.
Any possiblitys that this is a major problem or somthings going to expload?
Thanks again!
Old Sep 19, 2008 | 03:21 PM
dsmbruno's Avatar
transfer case it sounds like.... take it back bc its an expensive fix
Old Sep 19, 2008 | 03:25 PM
Note that the sound comes from the drivers side front tire. If i pop the hood you can hear it from the right side of the engine bay.
Old Sep 19, 2008 | 09:50 PM
Bump
Old Sep 20, 2008 | 07:30 AM
gsrboi80's Avatar
Totally normal read up theres 1 million posts about it. Your TC is fine as long as its doesnt whine at cruise
Some will say its the TOB and some will say its the input shaft bearing. Every EVO I have ever been in does this including brand new IX's and its louder once you go to an aftermarket clucth and flywheel set up
Dont worry drive and enjoy your car.
Old Sep 20, 2008 | 03:40 PM
Thank you, im morely worry free. If somethin happends, ill let you know
Old Sep 20, 2008 | 03:55 PM
03evo8kevin's Avatar
i have a simialar problem which a good friend of mine gave it a test drive last night and said mine needs an alingment and that the driveshaft could be warped from driving so long without the alingments so u could give that a try
Old Apr 28, 2009 | 06:46 PM
Bizo2's Avatar
im having a humming noise myself,
it sound like its coming from the middle of the car, i can hear more when i sit in the back seats
what could this be?
Evo_8_power
May 23, 2017 08:28 PM
Evo'lusive
May 11, 2016 03:59 AM
jrsimon27
21
Jan 29, 2008 09:35 PM
blood89
Lancer Tranny/Drivetrain Tech
10
Jan 25, 2008 10:01 AM
CT9A
Feb 26, 2004 07:37 AM
