I know this has been asked... Greddy Type RS
Old Sep 28, 2008 | 09:18 AM
vigilante.zen's Avatar
Does anyone know if this BOV has been successfully used? I am reading up on it and this doesn't seem to be such a good choice for the EVO. I just bought one and it comes with the recirc kit and all... Does this fix the problems or do I need to try and pick up another? Also thanks so much guys for all the help... I am new to the EVO.... Have dreamed after this car for 6 years now and finally have one!~
Old Sep 28, 2008 | 09:23 AM
SLOBRA's Avatar
I heard that the greddy rs doesn't hold boost pressures above 25 or so. A lot of people recommend getting a 9 bov since it is metal instead of plastic.
Old Sep 28, 2008 | 09:33 AM
rcheung's Avatar
That bov should be fine as long as it doesn't have the diaphram like they do in the type S. That is a known point of failure.
Old Sep 28, 2008 | 09:47 AM
PWevo's Avatar
It does have a diaphragm and on mine after about 2 months it started to flutter. Opened it up to find not 1 but 3 small cuts on the diaphragm.
Old Sep 28, 2008 | 02:40 PM
bas_evo's Avatar
i have the greddy rs on my evo and it's working wel. running 25 psi at the moment
Old Sep 28, 2008 | 02:52 PM
bboypuertoroc's Avatar
Veteran: Army
The RS is a piece of garbage.
Put your stocker back on or get a IX stock valve.
Old Sep 28, 2008 | 03:01 PM
sikrsix's Avatar
The greddy rs is fine. Its much better than the plastic VIII valve. You already bought it so use it. By the time you are heavily modified and need a new bov (25+psi) That one will be old/maybe leaking and "need" to replace it, rather than replacing it now just because.
Old Sep 28, 2008 | 03:57 PM
I guess my big thing is that so many people hate this BOV... I am just wondering maybe I should resale this one and get the IX DV... If this one isnt that bad I am going to just stick with it for now...
Old Sep 28, 2008 | 04:13 PM
KidEvo's Avatar
I've seen it work fine on a 30+psi meth evo.... I personally have a type-s that holds 25 psi w/o any issues.
Old Sep 28, 2008 | 04:20 PM
jid2's Avatar
Both the Type S and RS work very good when they are working.
I had a Type S on my car for 3 years, holding as much boost as you put through it - until the diaphragm crapped out. But when they do wear out the diaphragm is expensive to replace. I run a Forge RS now.
Ben yatson
Lancer Engine Management / Tuning Forums
Dec 15, 2016 08:38 AM
ChipperEvo
Sep 18, 2015 05:27 AM
timasse
Oct 8, 2013 11:41 AM
tsidrift1
29
Jan 8, 2009 03:25 PM
scottatyamaha
For Sale - Cars For Sale
27
Aug 20, 2008 12:24 PM
