Hi everyone, first post.....radiator help!
Old Oct 2, 2008 | 02:46 PM
DFelton's Avatar
Hey all,
I just bought damstr's evo 9 mr from MD and got it shipped up yesterday. Funny thing is the damn truck that shipped it broke down in front of my house, bwahaha. At least my new baby is here, but with a couple problems.
1.) The engine bay smells of coolant and there is a small amount missing from the resevoir, but the radiator is full with NO CLEAR SIGNS OF LEAKAGE. I've run the car and the smell gets worse but I don't actually see anything but a tiny amount on this hose *see pic*. WTF is that metal line with the nut on it? ? It isn't in the cooling system diagram I found online. I'll pressure test the system when I get a chance. I searched past postings but nothing was similar.
2.) Passenger side rear suspension (megan coilovers) clunk. WTF is that all about. Pillow ball mount?
I can't use my normal ramps to get this in the air to look underneath because its so damn low. What does everyone do to jack it up? Small jackstands?..
Thanks in advance!
Old Oct 2, 2008 | 03:54 PM
EpicEVO's Avatar
The metal line with the nut on it is your AC line.. That shouldn't have anything to do with it smelling..
Old Oct 2, 2008 | 04:15 PM
DFelton's Avatar
Great, retard question number one, check.
But there is just a slight film of coolant on that line. Anyone know where it could come from?
Old Oct 2, 2008 | 04:16 PM
DynoFlash's Avatar
Originally Posted by DFelton
Hey all,
Thanks in advance!
I would suggest clean the engine bay and then keep an eye out for leaks and or coolant comsumption when you drive the car or pushing of coolant into the overflow tank under boost
Al
Old Oct 2, 2008 | 04:19 PM
Q@EvoPowerMods's Avatar
Maybe where the plastic upper part of the radiator is pinched into the inner core has somehow come loose. Only a pressure test will reveal. You could start it up and see if the leak is seeping from that corner area. If it's a tiny amount you should be ok for now, but check it out with the pressure test...hope you find out what it is...
Old Oct 2, 2008 | 06:55 PM
DFelton's Avatar
Thanks Al, I've been a big fan over the years and I'm planning on making an appointment in the next few months. I'm up in Mass, so I'll be sure to come down for a nice dyno tune.
Old Oct 2, 2008 | 06:56 PM
DFelton's Avatar
Thanks for everyones input!
Old Oct 3, 2008 | 10:44 AM
srajeremy's Avatar
Hey all,
Thanks in advance!
maybe there was some spilled in the engine bay manifold etc and some got on the line if some got on the manifold that would explain why the smell gets worse. if youre worried pressure test.
Kkamshi
Aug 18, 2013 08:03 PM
Spoolin4g63
Jan 11, 2012 10:53 AM
Evo8*
Dec 20, 2011 03:46 PM
smokedmustang
23
May 9, 2006 09:40 AM
